I'll do the same with #19 as applying 12v to the motor in air pump, i.e., directly applying 12v, like this -- unless you say otherwise:misha wrote: 05 May 2019, 16:40#19 is sas system solenoid and it is operated by ecu,the same time it operates air pump...when it's needed.
It's normal state is closed.
You can check it by removing the connector, apply 12v to it and listen if it clicks while you opening and closing the circuit.
If it is clicking...it's ok.
Sometimes it can be full of carbon deposits which comes from exhaust manifold through a bad sas valve....check for it too.
#23 is one way valve and you can check it by blowing through it....air is going only one way.
If you can blow in both directions...it's bad.
Erikv11 allready answered about code and management with M4.4.
1997 850: throws DTC P0410 between 87-90 miles of drive Topic is solved
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
- Has thanked: 311 times
- Been thanked: 817 times
Yep that works.
Just touch the other lead to the battery posts, and remember the motor might kick when it runs (Newton)
If you connect it and they get stuck and fault, when you go to remove them you will blister your fingers.
He's already been through that (Einstein!) for the motor. Is asking about testing the solenoid. You're in sales, should know better than to get fooled by the graphics!abscate wrote: 06 May 2019, 15:32 Just touch the other lead to the battery posts, and remember the motor might kick when it runs (Newton)
xHeart
Graduating Einstein from sales to benefits.erikv11 wrote: 06 May 2019, 16:30He's already been through that (Einstein!) for the motor. Is asking about testing the solenoid. You're in sales, should know better than to get fooled by the graphics!abscate wrote: 06 May 2019, 15:32 Just touch the other lead to the battery posts, and remember the motor might kick when it runs (Newton)
Are the two solenoid connector pins intended for each (+) positive and (-) ground?
Unless it’s a pi chart, it’s too complicated for me...don’t you have cells to go look at?erikv11 wrote: 06 May 2019, 16:30He's already been through that (Einstein!) for the motor. Is asking about testing the solenoid. You're in sales, should know better than to get fooled by the graphics!abscate wrote: 06 May 2019, 15:32 Just touch the other lead to the battery posts, and remember the motor might kick when it runs (Newton)
xHeart
#19 solenoid passed! DOES IT WORK LIKE A SWITCH?misha wrote: 05 May 2019, 16:40 #19 is sas system solenoid and it is operated by ecu,the same time it operates air pump...when it's needed.
You can check it by removing the connector,apply 12v to it and listen if it clicks while you opening and closing the circuit.
The connection nipple for #22 holds vacuum and releases with click after a 12v charge. Whereas, nipple for #18 -- vacuum line to sas valve -- was open.
ALSO, extended the replacement air pump's negative wire -- it too tested ok afterward -- thanks Erik!
xHeart
The SAS was restored with a replacement air pump. Everything else was checked, cleaned, tested and installed. The rubber connectors/elbows are showing age.
The car is back running with more than 100 miles -- no CEL at this time. It could go for a State Air Team test next week.
xHeart
Sas restored, A/C recharged after 6 years of intermittent cooling, and finally PASSED Air Team emission this morning.
Thank you MVS!
Thank you MVS!
- 882 Views
Last post by garrisdw
- 601 Views
- 9 Replies
- 1421 Views
Last post by Stu70
- 9 Replies
- 2552 Views
Last post by misha
- 1039 Views
Last post by benpineapple
