Car shakes Topic is solved
dpayne20
Year and Model: 2006 s60
Post by dpayne20 »
Hey guys, for the past couple of weeks my car has been shaking when I accelerate. It is very bad when going around a curve turning to the left, and if I have a passenger it gets worse. I have gotten my tires changed and balanced and that did not fix it. Does anybody have any idea what is causing this?
Georgeandkira
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
Miles on your vehicle, please.
Drive next to a wall and listen for bad CV joint(s)-clicking.
Could be an engine mount?
Maybe wheel hop exacerbated by shot front struts?
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
CV joints and engine mounts, like Georgeandkira said, are my two guesses. I have dealt with shaking during acceleration in my '01 V70 twice; the first time it was due to a worn right inner CV joint and the effect was really bad, it shook everyone and everything in the car. The second time was due to a bad right motor mount. In that case it was more of a vibration and growling, not as severe but still a bother.
Cars I've owned:
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Seafoam withdrawal?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Shake upon acceleration may also be worn control arm bushings. Easy check www.youtube.com/watch?v=P1QaJbyjr2s
Either are old, either been replaced with some cheapies. Recommended brands Lemforder, Genuine and perhaps IPD HD - off sites like Fcpeuro or Ipdusa
dpayne20
Post by dpayne20 »
Georgeandkira wrote: 03 Jun 2019, 14:00 Miles on your vehicle, please.
It has 276k on it, and it's doesn't really click when turning except for a single pop when turning all the way left
oragex
Post by oragex »
That pop is the steering limiter, plastic piece on the control arm. See how worn it is an put some grease on it. You'll need to swap it if replacing the arm
dpayne20
Post by dpayne20 »
I think it is the inner cv joint on the front passenger side. I looked and the inner boot is totally ripped and there is a good bit of play
Has thanked: 1609 times
Been thanked: 4065 times
That’s probably it. You can’t just get a boot kit and clean out the joint, repack with grease , and pit OTT back in
Drive shaft will have to come off though.
prwood
Post by prwood »
dpayne20 wrote: 03 Jun 2019, 19:56 I think it is the inner cv joint on the front passenger side. I looked and the inner boot is totally ripped and there is a good bit of play
Did it look anything like this?
[youtube][/youtube]
That's what mine looked/sounded like. You can try repacking the joint and replacing the boot, but you may end up needing to replace the axle as I did.
Cars I've owned:
