98 v70 t5 320,000 never had pcv/ptc maintenance
- Been thanked: 4071 times
It is if the oil changes were religiously done every 5000 miles. I had mine at 160k and it was less than 10% blocked.
Do the “glove test” and if you don’t have crank pressure it’s not needed.
The engine oil on top will come from your bad oil cap gasket. Cheap fix, but go OEM
https://www.fcpeuro.com/products/volvo- ... gLQe_D_BwE
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
FCP must have a stock of them because Volvo in Sweden doesn't sell the gasket anymore. You have to buy the entire cap. Or buy the gasket elsewhere..abscate wrote: 04 Jun 2019, 01:07 Do the “glove test” and if you don’t have crank pressure it’s not needed.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
FCP stock is quickly depleting, I just bought 10 of them the other dayRattnalle wrote: 04 Jun 2019, 04:24FCP must have a stock of them because Volvo in Sweden doesn't sell the gasket anymore. You have to buy the entire cap. Or buy the gasket elsewhere..abscate wrote: 04 Jun 2019, 01:07 Do the “glove test” and if you don’t have crank pressure it’s not needed.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- Rattnalle
I'm pretty sure they'll find a new source for something as generic as a flat rubber gasket if needed850 LPT wrote: 04 Jun 2019, 05:48FCP stock is quickly depleting, I just bought 10 of them the other dayRattnalle wrote: 04 Jun 2019, 04:24FCP must have a stock of them because Volvo in Sweden doesn't sell the gasket anymore. You have to buy the entire cap. Or buy the gasket elsewhere..abscate wrote: 04 Jun 2019, 01:07 Do the “glove test” and if you don’t have crank pressure it’s not needed.
https://www.fcpeuro.com/products/volvo- ... gLQe_D_BwE![]()
Blech,...
Go check your turbo oil return line gasket....
- 15 Replies
- 2639 Views
Last post by j-dawg
- 1081 Views
Last post by BlackBart
- 1033 Views
Last post by polskamafia mjl
- 1470 Views
- 749 Views
Last post by magna224
