My daughter's 1997 850 N/A keeps throwing a phantom CEL. The light comes on, I put a scanner on it and it shows 1 code. When I try to read the code, it says "no codes." When I choose "erase codes" the light goes out.
Car runs fine. Any ideas?
1997 850 Phantom CEL
Craigd2599
- Year and Model: 2007 S40.
- Has thanked: 3 times
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
- Been thanked: 4068 times
What scanner are you using? You might need a higher end one to pick up the manufacturer codes
Craigd2599
It's fairly higher end. It has both stored and pending code readability. Code shows up on neither.
Craig D
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I haven't experienced this type of problem before, so I can't really offer any specific advice. I use an old Actron handheld scanner and it hasn't had trouble yet listing out the codes that are causing the CEL to turn on -- but that's just my particular experience.
It might be worth trying a different code reading tool to see if you have better luck... Do you have access to any other handheld code readers, smartphone based or OBD2/USB/laptop based code readers? Most car parts stores will read codes for free, so that could be a good option to try. Good luck!
Craigd2599
That's what I'm using. The scanner I have is fairly enhanced and it differentiates between readable codes and manufacturer specific codes.
That's why I'm baffled here.
Craig D
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
What is the code?
Craigd2599
There is no code. That's my point. The CEL comes and it will show a code in the queue and then when you select "read codes" it will tell you "No codes present"
Select erase codes" and the CEL goes out
Craig D
- Has thanked: 311 times
- Been thanked: 817 times
Try with another scanner, see if the problem is the scanner (or car-scanner pair) or the car. Take it to the parts store to have the code read for free, see if it behaves the same way with their scanner.
Craigd2599
I thought about doing that. Auto Zone's scanner isn't as good as mine
Craig D
xHeart
If true, then voltage is a suspect.
- 1576 Views
Last post by MadeInJapan
- 2715 Views
- 1022 Views
Last post by 93Regina
- 17 Replies
- 6516 Views
Last post by s10lowrider1994
- 9 Replies
- 2174 Views
Last post by Craigd2599
