2001 2002 AW55 transmission, history, stop/start software Topic is solved
urbex
Year and Model: 1994 855 T5R clone
Post by urbex »
Is this reason enough to avoid MY01/02 cars altogether? I'm looking at picking up another Volvo after about 6 years without my 850, and looking at some newer models. Is this stop neutral thing something I can feel while test driving a car to be able to tell whether it has had the programming updated or not?
Been thanked: 4065 times
Yes it is. If the car drives and shifts fine, no reason to avoid.
The stop neutral software will drop the transmission into N when you bring the car into a stop, then engage drive when you start again (brake release or gas?) If its bad, you will feel a big clunk.
I think 95% of cars have had it removed already. Confirm by VIN record at dealer
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Having a little fun with the engine
Georgeandkira
Has thanked: 79 times
Been thanked: 71 times
Post by Georgeandkira »
You zoomed well past 3500 rpm during your demo. I couldn't hear anything but the progressive roar of the engine.
Then, toward the end of the video, you accelerated up to 3,000 rpm 4 times....not your best video bro.
adbacker
Year and Model: 2001 V70 t5
Post by adbacker »
(hopefully this is in the right place)
I searched for someone who had this specific surging issue. While I found a few examples of folks with this behavior, I never found a definitive “this is what it was and this is how we fixed it.” I hope this helps one of those people ...
Short version:
The automatic transmission went out (as they do) on my 2001 volvo v70 t5. I had it rebuilt by a local AAMCO. They told me that the existing valve body was kaput, (expected) and put on a completely new valve body.
Getting it back, I noticed odd behavior. When cruising along between 30 and 35mph at a constant speed on flat level ground and with the rpm holding steady at approx 1600 ... the engine would start "surging". The rpms would drop by about 200, then jump back up, then down, then up and keep repeating at roughly 1 second intervals. As soon as I took my foot off the pedal, or sped up a little bit, or even added a little bit of throttle the problem stopped. At first I dismissed it as an anomaly, but as days passed and I kept noticing it, I decided that asking about it would be wise.
The transmission shop dismissed it as me being hyper-aware of a behavior that likely existed prior to the rebuild. After driving it for a few more days, I called back saying that the surge was happening so often I was certain I’d have known if the behavior had existed prior. AAMCO recommended to take it to the Volvo dealer to update the TCM software, as this often solved such behavior. The Volvo dealership had it updated ($200).
No fix. I could reproduce it on demand for the transmission shop (with a tech in the car) though they could not themselves. Further discussion revealed they didn’t have vida/dice so hadn’t done a full transmission re-learn. I did have a dice unit with vida, so took it out and did a full re-learn. That didn’t help either.
The shop determined that the car was spontaneously dropping into/out of lock up for some unknown reason.
After more diagnosis with vida, I discovered the SLU solenoid amp draw was dropping in time with the RPM changes. It would register at 0.6a, and then drop to 0, after which the RPM would jump. It looked like this:
After showing the evidence (with even more examples) to AAMCO, they reluctantly agreed to replace the SLU solenoid. It was replaced, I did a full adaptation (necessary? at this point why not) and the problem went away.
So if you’ve had your transmission rebuilt or a new valve body put in OR you just have the odd surging behavior while at a constant speed, flat ground ... it might be the SLU solenoid.
If you have access to vida/dice, hook it up and start graphing the engine speed, vehicle speed, and SLU current. If it looks like mine, well...that might be your issue too.
Long, drawn out, tl;dr version:
Chapter 1: The transmission man cometh
In September of 2017 I took my 2001 Volvo V70 T5 to a local recommended AAMCO for rebuilding. The transmission had died in early June but, since the rest of the car was in excellent shape we decided the cost ($4600) was worth it. After all, we were the second owners and getting a new car for $4600 that was in such good shape would have been a gamble. So off it went to be rebuilt. We got it back after about 2 weeks. (I think)
Less than a week after getting it back, the transmission seemed to "go out" just like when it died before the repair. No power, sluggish. Fortunately, I was able to nurse it into a safe parking location. I had it towed back to AAMCO to figure out what was going on. The next day they looked and found nothing wrong, telling me I should have just turned it off and back on again and it would have been fine. I was flabbergasted. A $4600 transmission rebuild and it was normal to have it seemingly die, and I should have known to "just restart" and everything would be fine?
Shortly thereafter I had it in to a local tire shop for new tires and an alignment. While replacing the tires, the shop told me that the front driver side axle CV boot had a hole, as there was grease flung all around the wheel well. This surprised me, as the Volvo had just been with AAMCO and they hadn't said anything about it. The tire shop also noted that the front control arm bushings were so shot, an alignment wouldn’t be possible. Well, whee.
As I was replacing brakes, rotors and front control arms, I also replaced the driver side axle due to the punctured boot. After the axle removal, I located where the boot had failed, and found it was not worn or cracked, but was a clean, moon shaped cut about 1/4” across.
It was also within a week of receiving the vehicle back that I noticed other, very odd behavior. When cruising along between 30 and 35mph at a constant speed on flat level ground and with the rpm holding steady at approx 1600 ... the engine would start "surging". The rpms would drop by about 200, then jump back up, then down, then up and keep repeating at roughly 1 second intervals. As soon as I took my foot off the pedal, or sped up a little bit, or even added a little bit of throttle the problem stopped. At first I dismissed it as an anomaly, but as days passed and I kept noticing it, I decided that asking would be wise.
Initially the transmission shop dismissed it (politely) as me being hyper-aware of a behavior that likely existed prior to the rebuild. After driving it for a few more days, I called back saying that the surge was happening so often I was certain I’d have known if the behavior was existing. AAMCO recommended taking it to the Volvo dealer to make sure the transmission control module was running the most recent version of the software, as this often solved such behavior. The Volvo dealership had it updated ($200) and I was again hopeful everything was fine.
This did not solve the problem. Exact same behavior. Back to the transmission shop it went. They were not able to reproduce the problem so I volunteered to take one of their techs for a ride with a diagnostic unit running to see what was going on. Sure enough, he was able to watch the rpms jump as I repeatedly reproduced the issue. They hypothesized that it was a failing throttle position sensor, the transmission control module, or the central electronics module. (CEM)
I took it to a highly regarded local volvo/bmw/mercedes shop to have them attempt to reproduce the behavior and and determine root cause. Hurless was not able to reproduce the problem either, but confirmed that the symptoms were not indicative of a failing throttle position sensor, though they agreed it could conceivably be one of the computers.
At this point, I wasn't ready to commit $1000 to have a computer module replaced without a firm diagnosis. Given that the problem started after the transmission rebuild it seemed likely that something in the rebuild was the cause. Fortunately enough, I'd purchased a Volvo DICE diagnostic unit a while back, so I hooked it up and started looking for anomalies.
I discovered the SLU solenoid amp draw was dropping in time with the RPM changes. It would register at 0.6a, and then drop to 0a, after which the RPM would jump. I took the volvo back to the transmission shop, volunteering to take a tech for a ride while providing my DICE+vida for better diagnostics than the tools he had available.
This is what the diagnostic from Volvo’s VIDA program looked like:
I was very surprised that AAMCO did not have the proper tools to diagnose a transmission they had just rebuilt. For me to have to diagnose a problem with the transmission I had just paid them $4600 to fix, spend days researching and gathering evidence to convince them it was an issue, and then *provide* them with the proper tools for them to validate the issue was profoundly disconcerting. At this point they continued to offer no help or suggestion other than to insist it must be a computer.
Chapter 2: Wherein the transmission demon is slain
At this point, I remembered the whole "you need to teach the transmission to walk again" process required after any major Volvo transmission work.
AAMCO had reset the transmission computer but given they told me the "reset" took only 15 minutes, I asked the shop if they'd done a full control module adaptation or only the reset the adaptive learning. They indicated that they were not aware of any such full adaption procedure. Given the full control module adaptation has to be initiated by the VIDA tool (which they didn't have), in retrospect this made sense.
I hoped that this was the missing link and a full control module adaptation would address the continuing rpm jump/SLU solenoid oddness issue. I found a long, quiet road in the middle of nowhere, and went to work. 2.5 hours later I had completed the procedure.
And the issue was still there.
Once again, I took it back to AAMCO. The tech I'd taken for a ride earlier confirmed what I'd shown, namely that the transmission was jumping into and out of partial lockup. I pointed out that it could be a defective solenoid. Though very skeptical, they agreed to replace the SLU solenoid before I tried the very-expensive process of beginning to replace computers. They also reluctantly admitted (when pointedly asked) that, indeed, the vehicle dropping into and out of lock up would prematurely wear the transmission.
The SLU solenoid was replaced. The transmission shop said that they were unable to reproduce the problem at my specified rpms (although they hadn't been able to in the first place), but thought they maybe had seen it at a higher RPM. I took it back out to the lonely road, went through the entire re-learn procedure. And the problem that I'd so reliably reproduce for weeks was gone. I was unable to reproduce it at any speed. GLORY BE! We had nailed that gremlin dead, dead, dead. I was bedraggled, disgusted with the transmission shop, but proud that I’d chased the issue down to conclusion.
Little did I suspect the heady sense of victory was to be short lived ... as the transmission gremlin handed off to an electrical demon.
But that's another story.
2001 V70 t5 - running
2001 V70 t5 - parts
FREEBUSINESSES
Year and Model: 2005 XC90
Been thanked: 3 times
Post by FREEBUSINESSES »
HELP...…. I have searched high and low and very few have experienced same message as I have on recently acquired 02 XC70 which has this message with no other codes, is there a way to know what needs to be fixed, it shifts fine, seems to have no issues in the few hundred miles I have driven checking out car. Those who have posted this same message never posted a follow up, and found only a couple posts over this same message, so it appears to be rare, it isn't even listed in the list of messages, this one is not on any list? Anyone here help on this issue? Car has 150K on it and had a record of trans service, so I assume that was a fluid change at 80K. So am having fluid service today and hopefully message can be reset by DICE which I don't have.
Thanks,
FREEBUSINESSES
UPDATE: Transmission fluid changed, no more message, so I guess this message is rare, but at least I found out what to fix next service, wish it would have just said, change transmission fluid.
I questioned type of transmission fluid this Volvo only independent used, thought it was suppose to be Mobil 1 3309 which was a non synthetic, but this shop says they only use synthetic transmission fluid, they have been top independent in area for 39 years, so who knows who is right.
Katten
Year and Model: S80 3.2 2007
Post by Katten »
I have been trying to get a grip on my AW55-50sn for some time now. Might have increased my problwm by trying ro fix it :(. Car drives and shifts fine cold. When warm i get a rather big flare between 2nd and 3rd. And a hard/jolting shift from 3rd ro 4th. Rest of the shifts are fine. Also N to D delay and the hard engages. N to R is fine.
All these issues are intermittent and does not occur at every shift. Seems 50/50 if is going to shift/engage correctly or not. I have tried ronresd up on what can cause this but cant find one common nominator. Might be a few solenoids that are worn/dirty/sticking? Or B4 servo piston acting up?
Gah, anyone with gesrbox experience able to give me some help? :)
petrikah
Year and Model: 2002 V70 non-turbo
Post by petrikah »
Hi Guys,
I went to the dealer today for an update of my TCM module software on my 2002 V70.
Currently i have software number 30759749AA (see screenshot below) and according to my internet reseach the update part number is 30646691.
How ever the delear told me (after charging $138.25 for diagnostics and telling me i need a new transmission for $6000), that there is no software update available for my TCM. Any ideea if thiss tatement is correct or not?
BenF
Year and Model: 2001 V70 XC
Post by BenF »
I think I'm about to go down this road and replace my valve body. It's going to have to be a DIY, I'm not going to throw $$$$ at a 2001 car.
That said, it's clean and only has 102k miles, having read a lot about this I think my symptoms are typical but not yet severe. I don't think I'm leaving too late to save the transmission. I also really like the car.
I have two questions right now.
Given that my car is an 01 is there any way my part can't be an early "no code" or A, which seem to be interchangeable ? I would much rather order the part before opening stuff up.
There seems to be lots of "remanufactured" or "refurbished" valve bodies on ebay for around $175 - $200. Has anyone tried these, I am skeptical. And suspect they are simply used.
There was also a $500 option from https://worldwidespecialtyparts.com/vol ... ng-number/ which seem more legit.
Any thoughts ?
