TCM swap
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Re: TCM swap
Post by vtl »
After 20-30 minutes ATF temperature raises, viscosity drops, leaks get worse.
Mobil is not the right viscosity, it has cSt@100 7.2, while OE ATF is 7.5 and has a better friction additives package. Shifts with Mobil are more harsh. You may try to cure it with HFM since you've got two boxes...
Installing additional oil cooler is a very basic job. Get Hayden Rapid-Cool of your choice and aluminium angles and bolts/nuts in Home Depot. Here's my frame for the cooler that mounts onto A/C radiator (it has mount holes):
And that's how it looks on the car:
Wise to install a 3/8" Magnefine inline transmission filter at the same time.
dejanaleksov
Year and Model: 2001V70xc
Post by dejanaleksov »
Nice thread, but did it solve anything? Vtl u r helping people, guess u like theese volvos to be driven more. Appreciate that. Cheers. BTW I have similar problem. Let's hope I will solve the problem and drive this volvo for a long time. Excellent car, not the gearbox
vtl
Post by vtl »
Transmission shifts much smoother when ATF is below like 85 degrees Celsius.
Gearbox is fine. "Lifetime ATF" is not. Flush it every 30k miles and it will run north of 200k miles with no issues.
Xc70V
Year and Model: 2006-xc70
Post by Xc70V »
abcdetech
Hi,
Just wondering if the flush helped solve your shifting problem from R to Drive. I’m experiencing the same problem and would appreciate hearing your experience.
Thx.
