Firstly, long time reader - first time poster.
I am struggling with a scary suspension problem with my 01 V70. The car pulls to the left under acceleration and to the right under deceleration. This problem is made worse with speed. It is almost impossible to keep it on the road over 45-50 mph. It darts around with the slightest change in speed. I have new tires, alignment has been checked by two different shops, recently replaced lower control arms and bushings. I had a bent rear track bar (foolishly used it as tow point to get unstuck from snow) but that has been replaced and rear full alignment completed afterward. I have had all 4 tires off the ground to check for slop in the steering and for loose and warn bushings. Everything seems tight. Where can I look next? Has anyone had a similar problem? I am at a loss and feel completely defeated. Seems like it should be obvious what is causing the problems. I will have to retire the 'ol girl if I cant find a solution!
V70 Pulling me off the road - like driving through a wind storm
mminniefield
- June
- Has thanked: 523 times
- Been thanked: 261 times
Subframe bushings. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Has thanked: 1497 times
- Been thanked: 3810 times
If they used Lower control arms of low quality, they can be bad out of box.
Recent thread in the XC90 with video - terrifying
mminniefield
I actually pulled good OEM control arms off of a donor car. ( I have read its better to go with used OEM over cheap new/reman) The noted problem developed more than 6 months after control arm replacement. and both sides seem to be in good shape.
- Has thanked: 292 times
- Been thanked: 765 times
Sounds exactly like bad front control arm ball joints.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
veektor
- Year and Model: 2008 S60
- Has thanked: 3 times
- Been thanked: 4 times
The control arms, especially the steel ones, are quite durable on their own, but the rubber bushings and the ball joints disintegrate over time. Those rubber bits are rarely worth reusing from salvage vehicles, unless you have definitive evidence those parts were new and installed on the donor very recently.mminniefield wrote: ↑22 Feb 2019, 15:14 I actually pulled good OEM control arms off of a donor car. ( I have read its better to go with used OEM over cheap new/reman) The noted problem developed more than 6 months after control arm replacement. and both sides seem to be in good shape.
My S60 had 200K miles, and those bushings looked very bad. After considering the individual bushing replacement, the cost and time involved in doing that, I chose to buy new Lemfoerder control arms, which include new bushings, and also replaced the ball joints. It was a physically demanding job, I would hate to have to revisit it any time soon.
If the rubber bushings are as good as you say, could it be the bearings?
- - Pete -
- Has thanked: 80 times
- Been thanked: 175 times
Sounds like a more extreme version of something I experienced on one of our cars recently.
With the car in the air everything felt tight, just like you say. But your car generates a lot more force than your body can muscling those front wheels around to check for play.
In my case I finally traced it down to a faulty tie rod end on the drivers side.
In your case this may make a lot of sense as well. The play on ours was almost completely imperceptible. But with a new Lemforder part in there our darting symptom is gone. Takes a while to manually get the alignment right on but you’ll get there eventually.
June’s suggestion of subframe bushings is also probable.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 531 Views
Last post by eightfifty2x0
- 9 Replies
- 1180 Views
Last post by bmdubya1198
