Hi,
I am ordering front ball joints for my XC70 2004 2.5T
I am also replacing the front lower table, in this case ebay item 273430197710
It seems to be the same lower control arm for both Base AND 2.5T
However when I go to buy the ball joint, for instance ebay item 122087681184
It says
This part is not compatible with 2004 Volvo XC70 2.5T Wagon 4-Door 2.5L 2521CC 154Cu. In. l5 GAS DOHC Turbocharged.
and
This part is compatible with 1 vehicle(s) matching 2004 Volvo XC70 Base Wagon 4-Door 2.5L 2521CC l5 GAS DOHC Turbocharged.
Is this an error ? Are there really different front ball joint for Base and 2.5T ?
thanks
Front ball joint for XC70 2004, Do Base model and 2.5T use the exact same part ?
- Year and Model: Lots
- Been thanked: 128 times
Go to FCP Euro for far more accurate part listings. Buying from some eBay sellers can be so risky.
If you're not satisfied with that get a running copy of Vida installed. Once you have a part number from Vida you can go to Tasca Parts and see if it's been updated by Volvo. So far this method hasn't failed me yet.
Critical safety related parts and eBay don't mix. Too much counterfeiting.
Get pricing from Volvo, IPD, FCP, eEuro and if your eBay price is different, run away.
The Volvo web store have the VIDA parts diagrams and you can enter your VIN To nail this down, too
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Good thing you asked here, you are about to buy very poor quality parts - the ebay 273430197710 122087681184 Search a little on internet about inexpensive parts, plus these are safety critical parts. You will be replacing them again after 6months/1year
Buy Lemforder instead by all means https://www.fcpeuro.com/products/volvo- ... it#fitment
The 'base' and 2.5T XC70 are same car, the XC70 was only delivered with the 2.5T engine
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
2.5T is Base (2.4T for 2001-2).shodanx wrote: 12 Jun 2019, 19:21 I tried on FCP euro, I selected volvo xc70 2004 and then it auto-selected base model as if there was no difference between part trims.
Same ball joint anyway, whether base or XC. I once tried a cheap brand of ball joint on a XC70 2001 and couldn't get it seated correctly. Wasted time and effort. Lemforder make great parts for Volvo if they're the real thing.
- 11 Replies
- 3164 Views
Last post by theWIFES_S70
- 355 Views
Last post by JelloBrick
- 20 Replies
- 1491 Views
- 679 Views
Last post by NC855R
- 2119 Views
Last post by SonicAdventure
