Hi,
I have a good condition 2001 V70 XC with 652000 km on the odometer.
However the speedometer reads about 15% too fast.
I have 205/55R16 tires on there but I believe it was originally 215/65r16. This should account for about 8% of the difference.
Is there any way to adjust the speedometer to match actual speed ?
2001 V70 XC , speedometer misreads 137km/h when actual speed is 120km/h
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Correct Tyre size would be a better option. As it is now you're getting the wrong gear ratios and everything as well as the speed showing too high. 214/65-16 is indeed the correct one. The car is programmed so it'll show a few km too high with the correct tyres as well if compared to a GPS but the difference should be quite small.
Speedometer can be adjusted but you need to find someone who can change the carconfig to do it.
shodanx
- Year and Model: xc70 2001
Can the adjustment be done using VIDA ? (I have it working)
This is my backup car so I'll be with these tires until they wear out (probably 2 more summers). So I'd like to adjust if possible.
- Rattnalle
A regular vida doesn't have the capability to change the carconfig. People who can reprogram the car to add equipment should be able to help though. I only know a guy here in Sweden not on your end. But im thinking trying to swap tyres with someone is probably cheaper.
shodanx
Thanks,
Is this a special version of vida ? Does it have a distinctive name I could search for ?
This is my backup car and I don't want to spend more on tires than I already have. So it will stay like that until they are used up.
- Been thanked: 4068 times
You probably got the speedo from an R.
( MVS humour)
( MVS humour)
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Smartphones have speedometer applications. Mount it safely on window or vents using magnets.
Had this mount for a over a year in my P2.
https://www.amazon.com/IPOW-Universal-M ... 146&sr=8-3
shodanx
I have an android auto dock works great but if I want to use the gps app I need to exit android auto, it's kind of annoying but that'll do I guess.
Though, the computer is so conveniently accessible, I am tempted to mess with it with my microcontroller programming tools
- 12 Replies
- 244 Views
Last post by Dzielnywojak123
- 1993 Views
Last post by coflynn
- 1159 Views
Last post by Rattnalle
- 23 Replies
- 3963 Views
- 1683 Views
Last post by 850_GLT_Owner
