Hi
Have a C70 2000
6 weeks ago my front brakes starts to sqeeks/scream
Have changed discs and pads twice and hoses and lubicated gliders.All original parts
Have cut edges of pads and tried scream plates
Have removed anchor plates
Changed to 16" discs and retainer from 15" last year
Noise comes when brake soft
Will change back to 15" help ?
Can not find cause
Please help
brake noise
- Has thanked: 2207 times
Just to confirm you have use Volvo original parts? Did you change from 15" to 16" rims last year? Or did you change the diameter of the rotors from 280mm to 302mm?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
The pads likely have not been fully bedded. Some companies want you to get them done immediately after installation while others after 500 or so miles. It's the air gap. Mine still squawk like the video while pulling into the driveway but it is very slight now as it approaches 500 miles. Almost time for the bedding process according to EBC Brakes. It is that loud. Check your manufacturer for instructions.
E92 m3 vs Volvo 850 Nürburgring - Embedded Video Link Not Working? Use Link.
"www.youtube.com/watch?v=D-ouO8Ii74s"
- MoVolvos
When I was in China 1985 I saw some guy driving up and down the street and braking hard quite a few times (no clue). Worked at Pepboys & Acura in the mid 90's and did not recall bedding brakes either. I think I started to about 6 years ago after purchasing a set of Front Powerstops for a 2003 Lexus GS300 because they say it's a must. The brakes are still on the car. Check the Manufacturer for recommendations.
- MoVolvos
Check the run out on the rotor or make sure all the surfaces of the rotor and wheel are clean. The air gap of pad and rotor during light braking is not completely closed. Check for debris in the pads also.
- MoVolvos
Reading your OP you may have a caliper that is sticking slightly. Regardless something is causing the air gap. Can you tell if it is from one side only or both sides?
jantt
- Year and Model: C70 2000
- Been thanked: 2 times
All is cleaned and fine
Have cleaned and greased it 4 times
Have tried with 3 pads
Yesterday afternoon I cleaned all and mounted new pads. Drove 2 km and noise came
Must try to drive some km and see if it stops
Have thinked that it could be the calipere, but workshop says no.
Will try to spin wheels today
- 2307 Views
Last post by MoVolvos
- 2450 Views
Last post by Ou2mame
- 1171 Views
- 727 Views
Last post by jtp
- 2745 Views
Last post by RickHaleParker
