Door Handle Does Nothing
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi,
The inside door handle on the passenger side does not do anything when pulled. No noise and the door does not open.
How hard is it to fix the linkage on these things, or could it be worse? v70 1998
Thanks.
Has thanked: 312 times
Been thanked: 818 times
If the outside handle works fine, I would expect it to be a simple fix. If the linkage has fallen off then reconnect it, if the cable has broken then replace the inside-handle-and-cable assembly (junkyard trip there). Those are my two guesses.
I'd get on it soon, as you don't if the other handle stops working then things get much more difficult to fix simply because you can't get the door open to remove the panel. When you do pop off the panel to actually figure out what is wrong, you may want to buy a couple new plastic snap connectors. The 20 year old ones tend to break easily.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
erikv11 wrote: 19 Jun 2019, 09:41 If the outside handle works fine, I would expect it to be a simple fix. If the linkage has fallen off then reconnect it.
This. I helped my buddy fix his P2 S60 with the same symptoms, simple quick reconnect fix.
Also -> Amazon link
Has thanked: 1611 times
Been thanked: 4072 times
Just another reason sunroofs are great
MrAl
Post by MrAl »
Hi,
Oh thanks to you all for the suggestions, especially about the fact that if the outside goes bad too im screwed.
The sunroof idea also sounds good, if i had one. Another way out.
You know what blows? I found out when a very significant lady friend tried to open the door. I was embarrassed to no end. I had to open the window so she could reach out and use the outside handle if needed. Of course i open the door for her anyway but i hated that she had to experience that.
Ouch. That could end a first date pretty quickly.
shegarty
Year and Model: 1998
Has thanked: 12 times
Been thanked: 8 times
Post by shegarty »
MrAl wrote: 20 Jun 2019, 03:49 You know what blows? I found out when a very significant lady friend tried to open the door. I was embarrassed to no end. I had to open the window so she could reach out and use the outside handle if needed. Of course i open the door for her anyway but i hated that she had to experience that.
This is a great way to screen potential partners ... if she doesn't appreciate your quirky old Volvo that sometimes needs a little love, let her go :wink:
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
My test would be if my date could yoga through the sunroof!
:-D
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
abscate wrote: 21 Jun 2019, 10:08 My test would be if my date could yoga through the sunroof!
:-D
Nah, hand her gloves and invite her to a good game of alternator tetris =)
2023 Lexus RZ450e -66k
MrAl
Post by MrAl »
Ha ha.
It's strange that i did not experience the problem before that.
I have had other passengers before that.
