bill d cat
Year and Model: 1998 V70 T5M
Been thanked: 7 times
Post by bill d cat »
brunocerous wrote: 18 Jun 2019, 15:48
That looks great! Did you use any solvent to clean up the trim?
Thanks! After scraping I did some light sanding with sandpaper and a Dremel sanding drum where needed. Then I cleaned up the flakes and dust with a shopvac followed by a dusting with a rag with isopropyl alcohol to give the tape the best chance to stick.
I didn't dare do more. The plasticizers are mostly gone from the plastic after 21 years and I didn't want to make it even worse.
("Plan F" is to locate a V70 or XC70 with a roof rack in decent shape on its way to the crusher.)
'98 V70 T5 232K mi., 5-speed manual, 3rd evaporator, 3rd windshield, 7th remote shell, heated velour seats, factory HD suspension, IPD stabilizer bar, Volvo strut tower brace and skidplate, XC grill, E-Codes, V-1, JB Weld, Duck Tape, zip-ties, Mobil-1 since new. Goal: MADE IT to the MOON! (was 221,524 miles at perigee November 14, 2016.)
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Over the past few days I have been working on making a 3d printed door trim piece. Specifically the piece that surrounds the inner door handle. I wanted to start with something simple to learn from it and hopefully start designing more of the complex parts. For now I am prototyping using PLA in black since I have it lying around. The final piece will be printed in a color that best matches the tan interior.
Today was my 4th iteration of the design and finally produced a piece that fits quite well.
Please excuse the duck taped panel. She survived a tornado so she gets a pass.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Nicely done! 3D printing fascinates me... I love that we have the ability to reproduce these sorts of parts now. Maybe the material will be better and last longer than the old Volvo plastic!
ZionXIX
Post by ZionXIX »
bmdubya1198 wrote: 20 Jun 2019, 18:59 Nicely done! 3D printing fascinates me... I love that we have the ability to reproduce these sorts of parts now. Maybe the material will be better and last longer than the old Volvo plastic!
That is the goal! I'm thinking the final part should be made of ABS or PETG. I've only worked with ABS but both are supposed to have high heat tolerance which is a necessity here in Texas.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
ZionXIX wrote: 20 Jun 2019, 20:32
It's not so much heat and cold tolerance that's the issue. The plastic needs to withstand extreme temperature changes. On top of that, the plastic HAS to be UV stable, which is expensive and hard to do.
Nice work on the trim piece. I really think 3D printing is the future for reproducing old car parts.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
bmdubya1198
WhatAmIDoing wrote: 20 Jun 2019, 21:35I really think 3D printing is the future for reproducing old car parts.
Definitely. That’s one innovation for the automotive world I can really get behind. As for the other things that people say are the future of the industry... like electric cars... not so much.
WhatAmIDoing
Running into a new trend with the T5M. Occasionally, starter will not engage. Turn ken to POSII, all the lights come one, fuel pump primes, everything works, turn to start and click. Car will bump start via popping the clutch. Today, I was facing downhill into a parking stop. I kept turning the key and eventually I heard the starter click on a few times until it finally started working again as it should. Thoughts?
ZionXIX
Post by ZionXIX »
In my research I came across ASA filament which is like ABS but much more UV resistant and intended for outdoor use. It's a bit more expensive but not much. It's like $10 more per roll than ABS. The real challenge is finding good colors.
Been thanked: 4068 times
WhatAmIDoing wrote: 20 Jun 2019, 22:15 Running into a new trend with the T5M. Occasionally, starter will not engage. Turn ken to POSII, all the lights come one, fuel pump primes, everything works, turn to start and click. Car will bump start via popping the clutch. Today, I was facing downhill into a parking stop. I kept turning the key and eventually I heard the starter click on a few times until it finally started working again as it should. Thoughts?
Worthy of its own thread but try the bypass wire to isolate the problem to the starter or the switch/wiring.
'remote starter connection' should be a good search string
viewtopic.php?f=1&t=78989&p=499047&hili ... te#p499047
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
That 3d printed part looks good :wink:
I got a good deal on some discs and pads for the V70, still need a few things including the infamous 302mm bracket
Also tapped my spoiler back, it's not flopping away anymore :mrgreen:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
