brake noise
jantt
Year and Model: C70 2000
Post by jantt »
just come to thinking of could it have something to with the hydraulicpump ?
because sometime I think the noise comes from different wheels
have driven with different people and some front and others say back and some says left and others right
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
How about swapping the rotors left to right and right to left if they do not have directional slots or directional drilled vents? Be sure to note any difference in the noise or perhaps it'll go away.
jantt
Post by jantt »
Is the same rotor on both sides. No left or right
I can try to swap, but sometimes it`s like the noise from front and sometimes from the back
MoVolvos
Post by MoVolvos »
C70 2000 Brakes.png (163.45 KiB) Viewed 811 times
jantt
Post by jantt »
yes all is clean and yes it`s new
MoVolvos
Post by MoVolvos »
Part 17 new from last year or now while fixing noise?
So looking at the original post again till now:
1) Changed to 16" last year.
2) 16" started to make noise 6 weeks ago.
3) Changed a bunch of parts and adjusts
Assuming 1 ~ 3 is correct did the noise changed at all anytime during all the change in parts and adjustments?
jantt
Post by jantt »
Yes 1 to 3 is right and noise didn`t change
Just think if the pins that comes out from the hydraulic box to the controlunit is hanging, that is could cause it ?
jantt
Post by jantt »
No the pins from this that goes into the control unit
https://www.ebay.com/itm/NEW-Genuine-AC ... SwHN9cetzO
MoVolvos
Post by MoVolvos »
Since the noise began with the old set of brakes then a part from last year which was not changed out is causing the problem. Did you hit any large pot holes or run up a curb? Alignment been checked?
Not familiar with that part but why do you suspect that unit?
jantt
Post by jantt »
Yes started with old parts and then started to change
Has changed rotors, pads, caliperes and hoses
Has hit no holes
I suspect that part because sometime I think the noise comes from left and right.
Sometimes front and somtimes back
The pins move in and out into pistons in the control unit
If the pins sometime hang then it could cause it?
