bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Did some stuff on the S60 :mrgreen:
16t is installed and it runs pretty well! I need to figure out why it won't move now, I have a feeling the passenger side axle isn't seated. The PO told me the transmission just randomly stopped working, and that was that. He towed it home and parked it, then it sat until I bought it.
The car rolls in park and makes a little grind when I put the shifter back in park. Doesn't move in any gear. Interestingly enough, the passenger outer CV boot is torn and the axle seal is leaking. I'll investigate further tomorrow.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Yesterday -- Brother and I completed delta link replacement (finished both sides as opposed to only one) and replaced rear brake pads on the '99 V70. Pads were shot. Delta link went really well since we made all our mistakes (or should I say maximized our learning opportunities?) a few weeks ago on the passenger side.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Been thanked: 4065 times
Used my T5 as An anchor to drop a dead 35 foot pine between mine and neighbors houses,
Worked well.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Installed a new SS Maximizer exhaust on the wife's '97 855GLT, along with a used Viva rear chassis brace we had re-coated.
bmdubya1198
Got the S60 driving. PO was obviously a pro mechanic, because the transmission that magically failed is fine! Turned out the passenger side axle was broken, which would explain the grinding it made when I put the shifter in park as well as the fact that the car would roll in park.
Took it up and down the street and it rides surprisingly well considering the control arms, struts, tie rods, etc. are totally shot.
I'll have to post pics of the old axle shortly. It totally separated right near where it goes into the transmission. Plus the inner CV joint fell right apart when I went to pull it out, so that didn't help.
cmblackburn
Year and Model: 1998 S70 T5M
Been thanked: 7 times
Post by cmblackburn »
Well, I got the thing running again...with 5 forward gears instead of 4, and I get to choose them! :mrgreen: :mrgreen:
Now slowly relearning to drive stick. Just waiting on my T5M ecu to arrive and she will be 100%
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
cmblackburn wrote: 24 Jun 2019, 22:28 Well, I got the thing running again...with 5 forward gears instead of 4, and I get to choose them! :mrgreen: :mrgreen:
64782062_10219359049027335_4746146205921181696_o.jpg65031657_10219364381280638_6476781609734373376_o.jpg
wow, what a beautiful car! And congrats on your conversion, great job!
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
dalel
Year and Model: 1998 V70
Has thanked: 29 times
Post by dalel »
Boy do I feel like an idiot. Had grumbles and occasional clunk coming from, what I was sure, the left front of my 98 V70. Absolutely not allowed to work on cars at the apartment and I had no record of ball joints (or control arms) ever being replaced so I took it to the local independent. While waiting for them to come out and get my car, for no reason I can explain, I went around the car touching wheels. Left rear was H O T! This changes everything. Turns out that the ball joints were fine but the ceramic had fallen off the parking brake. Still odd that from inside the car I was sure the noise was coming from the front. (You would think, at the very least, I'd have gotten a P0455 idiot light.)
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Had a productive session working on the instrument cluster. Correct my mileage and replaced the tiny broken gear. I'm alalsalalso worried I may have damaged some other gear during the repair. Only time will tell.
While I was in there I decided to change out the 4 main bulbs and the 2 smaller bulbs for the info display.
Which dash lights in the VDO cluster are supposed to have bulbs? When pulling the cluster I noticed 4 slots have no bulbs. One is labelled TRACS, which I don't have so not worried. Another is the "LOW OIL LEVEL". There is one blank and the last one is a symbol I have never seen before.
Thats the heated rear third seat indicator. It looks just like the CAT overheat warning on earlier cars.
