- Has thanked: 316 times
- Been thanked: 531 times
Wow, that's nasty! They really should have installed cabin filters on all of these.
- amblerman
- Year and Model: 1999 s70
- Has thanked: 2 times
- Been thanked: 70 times
The antenna on my 99 s70 was no longer retracting so I decided to swap it for a fully functioning antenna from a 98.
And I discovered yet another difference between 98s and the 99-00 models.
The antennas are the same, but the drainage tube at the bottom of the antenna, the antenna mounting bracket and even the top nut/mount are different between the two years/generation of cars.
Thankfully, I could swap them all over from my broken 99 antenna to the 98 but I was surprised at how many changes there were on just the antenna.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
That's ok. What is your process for fixing it? I tried using a photoeditor to rotate and save the picture. From now on my camera button needs to be on the right for landscape to be in the correct orientation.matthew1 wrote: 30 Jun 2019, 18:09 Fixed the resistor pic at the cost of being able to click on it to get a larger version. Sorry about that.
- Has thanked: 2861 times
- Been thanked: 1332 times
You have to strip the EXIF data that rides along inside the file. I Export in Photoshop to achieve this. There are probably a few dozen ways (apps) to do it.
- Been thanked: 4071 times
Are you still getting AC with the corner of that evap munched by AC sharks? Incredible.ZionXIX wrote: 30 Jun 2019, 11:43 Good Sunday all,
Since were on the subject of AC systems. I'm in the middle of replacing my blower motor and resistor. While doing that I decided to shop vac around the evaporator a bit. This is actually the first time I have ever physically looked at the evap and I this vehicle has gone 23 years without a cabin filter. Why didn't volvo make this standard? A shop vac is only able to do so much. The crud I'm pulling off is well adhered to the evap fins. I'm impressed any air was getting through. Pics below to completely disgust your Sunday out.
- ZionXIX
Still ice cold. I'm impressed to say the least.
Ice cold? Yep, incredible.
Ah, looking closer what I thought was a gnawed evaporator is in fact a bar code sticker.
It is still impressively gunked up.
- ZionXIX
Yeah I removed that too. And for some reason a lot of paper straw wrappers.
