Bosch #0 123 505 014 Alternator Parasitic Draw Topic is solved
dyn blin
Year and Model: 1997 850 Wgn
Post by dyn blin »
Good evening all, long shot- I have the alternator listed in the topic, Bosch #0 123 505 014
I've been chasing an almost 4A parasitic draw. I recently replaced the voltage regulator trying to track some weirdness with my ABS module and speedo that started manifesting during a 1500 mile drive in some heavy heat. Charging has been good (and wasn't too bad on the old voltage regulator, but it was time after looking at the brushings).
In hindsight, I should have checked the alternator for the draw first. I did the normal battery, charging & voltage drop testing and all came in within spec, so I ended up checking every fuse and relay. When I finally got o disconnecting the alternator, the "key off" draw fell from 3.86A to 20mA.
The question- does anyone know of a source for the diode stack to replace in the alternator?
'97 850 GLT Wagon- Driving to see 300k in the rearview
Been thanked: 4065 times
Dyn
Take your alternator to a good electrical shop and have them rework it unless you are really tight for bread.
Get a used one off eBay if you need to run the car, you can also run without for a few days if you’re battery is good and you can charge it overnight
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
what do you mean run without?
Take off the serp belt and run without alternator, PS, or AC.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
abscate wrote: 02 Jul 2019, 06:43 Take off the serp belt and run without alternator, PS, or AC.
This is a great upper body workout if you want to build some muscle :o
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
850 LPT wrote: 02 Jul 2019, 07:18
Body by volvo
ZionXIX wrote: 02 Jul 2019, 11:06
Body by volvo
Ive got the roll part down well.
dyn blin
Post by dyn blin »
Too funny. Does the BBV include the core strength from leaning over the open engine bay? 'cause all I feel is a sore back.
Thanks for the suggestion. I think I've found a lightly used AL 0752X locally while I track a local shop.
Marking it solved.
Yeah, yanking those alternators is tough. We call it “Alternator Tetris” here
