Hi
So basically i changed my fuel pump assembly and that part went well. Now i've run into a snag. The metal fuel line connector, that connects to the fuel pump, doesnt want to attach. I've tried rotating the pump, different angles and such but no luck.
As i understand it, it has to go on just right.
Does anyone have experience fitting the connector?!
Fuel line connector v70 awd 99
- Has thanked: 2210 times
They should just snap into place. Can you take a picture of the problem hose and connector as it may help me and others to help you get this figured out when we can see what you are trying to do.
Captainhat
- Year and Model: 1999 2.5t awd
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
That doesn't look like the right fitting to me. The original should have a plastic ring that protrudes further down the metal nipple on pump cap. The one pictured looks like a fitting for a line/nipple with a flange. The 4 spring "fingers" go past the flange and to release you slide a cuff down the line and it pushes the fingers towards outside so they clear flange for removal. If that type fitting was used on that pump cap you would not be able to get the release tool in place to ever remove it. the one shown will not latch where it can't be pulled off as the nipple on that pump has no flange (maybe calling it a lock ridge gives a better description).
- Has thanked: 1611 times
- Been thanked: 4075 times
The other tip off is those hose clamps are not appropriate for fuel injection applications. they will loosen over time, and being buried under the back seat and metal, won't be inspectable easily
replace with one use, oetiker or at least banded fuel injection clamps with Loctite applied.
Captainhat
Ok. But the one on the right is original? That one didnt have 4 metal clips securing it. So the two connectors are wrong? The older one is on.
Do you have a link to the correct fitting? I can't find anything.
Abscate, you should've seen what the previous owner did. Where those hose clamps are, there's a plastic tubing that connects between pump and filter.
- 6574 Views
Last post by BigSpud
- 2363 Views
Last post by Centex Swede
- 718 Views
- 283 Views
- 25 Replies
- 4353 Views
