- Ocelot
- Year and Model: 1998, S70
- Has thanked: 61 times
- Been thanked: 17 times
Yesterday I was cleaning out my S70 from a roadtrip to Poland. Everything went perfectly fine and I'm still amazed how comfortable the S70 is after driving for 10/11 hours straight. But when I was done cleaning out the car and drove it to my parking space I noticed the lights on the ECC were flashing. Well, then read the codes you might say. But... how does one do that on a 1998 S70 with the B5252FS engine (not sold in the US if I remember correctly). It doesn't have the Bosch Motronic set up, but a Siemens Fenix system. It does have the OBD port under the armrest ofcourse, but what do you hook up on that port?
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Recent car
- Stu70
- Year and Model: 2006 Sonic VR GT
- Has thanked: 34 times
- Been thanked: 26 times
Look up flash code reader in the repair data base -an LED, a push button and a few lengths of hook up wire.
20 valves are 10 too many anyway...
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
My Autel reads the ECC codes via OBD on my 1999.Ocelot wrote: 03 Jul 2019, 02:50 Yesterday I was cleaning out my S70 from a roadtrip to Poland. Everything went perfectly fine and I'm still amazed how comfortable the S70 is after driving for 10/11 hours straight. But when I was done cleaning out the car and drove it to my parking space I noticed the lights on the ECC were flashing. Well, then read the codes you might say. But... how does one do that on a 1998 S70 with the B5252FS engine (not sold in the US if I remember correctly). It doesn't have the Bosch Motronic set up, but a Siemens Fenix system. It does have the OBD port under the armrest ofcourse, but what do you hook up on that port?
If you are getting good AC, check the recirc flap for correct operation, that is often an ECC AC problem
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Fenix can be read with VOL-FCR, which means a homebuilt flash code reader will also work. Pins are the same as for Mortobic 4.3 if I recall correctly.
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
Replaced right front lower engine mount and sway bar endlinks with Lemfoerder. Don't buy cheap no name, they lasted 5k miles. DUH!!!!!!!
- Ocelot
I'll be heading out today to the electronics store to make myself a flash reader. Any tips on how to check the recirc flap on correct operation?abscate wrote: 03 Jul 2019, 05:11My Autel reads the ECC codes via OBD on my 1999.Ocelot wrote: 03 Jul 2019, 02:50 Yesterday I was cleaning out my S70 from a roadtrip to Poland. Everything went perfectly fine and I'm still amazed how comfortable the S70 is after driving for 10/11 hours straight. But when I was done cleaning out the car and drove it to my parking space I noticed the lights on the ECC were flashing. Well, then read the codes you might say. But... how does one do that on a 1998 S70 with the B5252FS engine (not sold in the US if I remember correctly). It doesn't have the Bosch Motronic set up, but a Siemens Fenix system. It does have the OBD port under the armrest ofcourse, but what do you hook up on that port?
Recent car
Recent car
Key on. Lift up the flap under hood, push recirc button and see if flap closes and opens when switch is cycled
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
The ‘00 V70 never fails to keep me on my toes. Most recently, it’s giving me a P0600 (serial communication error).
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
I didn’t do anything to my car yet but I picked up some parts for it today at the pick n stab. The plan was to collect a couple of pounds of BMW nuts and bolts but I stumbled upon this nice C70 convertible. Easy under 100K and a 2004. I have had some annoying brake problem for a long time now. Brakes require a lot of input force to work, pulsating feel in pedal sometimes etc. I decided to just pull it all to get the problem over and done.
Neck totally fried but the parts look awesome where they are sitting on a shelf in the garage
BMW 540i 2002
S70 Base 2000
- Has thanked: 316 times
- Been thanked: 531 times
Spent the last two days cleaning the S60’s interior. It turned out pretty nice! I still need a driver door panel and a driver seat eventually, but everything else is in really nice shape.
Also received the upper torque mount today from FCP, now the strut brace is finally installed. The old bushing was completely missing when I got the car, so I couldn’t install the brace.
The new mount makes the rest of the engine bay look like crap.
Timing belt, cam seals, water pump, PCV, tires, control arm bushings, and more to come!
