Wouldn't pass State Inspection
- Has thanked: 2652 times
- Been thanked: 1240 times
Re: Wouldn't pass State Inspection
I merged List Of Parts/Name To Verify For Me and Wouldn't Pass State Inspection.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 35 times
- Been thanked: 41 times
The labor cost of pressing in new bushings into the original control arms will be high. If you're not doing the labor yourself then purchase new control arms to save money.
Right lower quality:
https://www.fcpeuro.com/products/volvo- ... e-30635230
Left lower quality:
https://www.fcpeuro.com/products/volvo- ... 0-30635229
Right higher quality:
https://www.fcpeuro.com/products/volvo- ... 30635230oe
Left higher quality:
https://www.fcpeuro.com/products/volvo- ... 30635229oe
You'll want to mount new ball joints on those new control arms
Ball Joint moderate quality x2:
https://www.fcpeuro.com/products/volvo- ... s60-xc70-2
Ball Joint higher qaulity x2:
https://www.fcpeuro.com/products/volvo- ... 0-274548oe
Left lower quality:
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Changing rear brake pads is exceedingly simple. Drive out two pins with a drift, remove pin retaining clip in the process, wiggle out old pads. Compress piston with a big pair of channel locks or large c clamp. Wiggle in new pads and drive in new pins with clip.
Of course, car is on jackstands with rear wheel removed.
Remount rear wheel and bed in new pads. Voila.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 151 times
- Been thanked: 4 times
Chrism, no you don't have that wrong. I can't figure out why the guy I have been going to for years wants to send me elsewhere to a place that would cost be a fortune. Maybe he just doesn't want to deal with my fixes and thinks that because it is a Volvo it has to be done at a Volvo expert shop.
MDK, I do at least have ramps so maybe I cans search up a "YouTube" video for doing what you wrote. I need to borrow or rent an impact wrench just in case I think.
Mr. Detail
Thanks E Showell. I think i will have to go buy a big pair of channel locks or large c clamp. Can I reuse the old retaining clip?
Well Mr Detail.. MDK here. I guess it's really a question of upper body strength. And your over fitness. I bought the car ramps from tractor supply.. about 40$ back then. High strength plastic. Secondly..I did it all without any air tools. Just make sure it's real tight. I know there are torque specifications, but what's a Newton meter?
- E Showell
I suppose you could reuse the clip, but I generally replace them. Brake hardware kits are cheap -- c. $10-12 and will include the pins and clips for both sides of the car. Don't forget some brake grease to apply to the back side of the pads to avoid squealing.
'95 855 auto (sold)
'95 855 auto (sold)
Mr. Detail
Thanks gentlemen. MDK, which flag is that? Maybe Nike could use that one on their new shoes.
- Has thanked: 1498 times
- Been thanked: 3810 times
Its a real piece of history - the Revolutionary Air Force, the motivator for the modern day RAF.Mr. Detail wrote: ↑09 Jul 2019, 05:46 Thanks gentlemen. MDK, which flag is that? Maybe Nike could use that one on their new shoes.
You know Mr detail... when you drive a Volvo people think you own a bank or a small conglomerate....
get the parts you need...go to another garage and have your parts installed we're not swapping spit here.. get it the alignment and show the other garage your backside..
