OEM Tool kit screwdriver: Why?
Been thanked: 4065 times
Who still has the pair of Michael Jackson gloves from their tool kit?
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
Tip and/of Trick:
All of my Volvos except my 1999 S70 have had a place on the wheel where the pin on the rotor could engage and line up the lug holes properly. The 99 S70 wheel have no provision for accepting the alignment pin. A guy at a tire store gave me an aluminum alignment tool that is threaded on one end and rounded on the other which works just fine - when I can find it...
I used to have to mount heavy x-ray tubes to overhead gantries that had four bolts in the back. Once you got one bolt in, the other three were easy, but that first one was a real bitch holding a 70 lb weight at chest height. A more experienced guy showed me that you could take a standard bolt and grind the head off to make an alignment tool. You thread that in by hand, hang the weight on it, align the other bolt holes and then remove the alignment tool and replace it with the last bolt.
I was going to get a long bolt the same thread as the lug nut and cut the head off, but the tire guy did me a favor by handing me the exact tool.
All U.S. market models.
All running and on the road.
gmh
Year and Model: 2016 XC60 T5
Has thanked: 28 times
Been thanked: 22 times
Post by gmh »
abscate wrote: 12 Jul 2019, 05:03 Who still has the pair of Michael Jackson gloves from their tool kit?
850 tool kit.jpg (298.14 KiB) Viewed 1323 times
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
gmh wrote: 12 Jul 2019, 10:05
Im not putting my hands in those.....looks like the Wicked Witch of the East...
Come here my pretty - and Ill give you a P0455
Screen Shot 2019-07-12 at 9.33.57 PM.png (464.68 KiB) Viewed 1313 times
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Whatever you do, don't lose a single glove... =)
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
first the screwdrivers. and now the gloves. where are mine? but then, I have a really nice leather bound booklet for my manuals that only the R models got. ha! who's fancy now, Steve?
1996 855 R,
2010 V70 D5,
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
There are no flat screws in the 850/s70 and only 1 Phillips head on the entire 850's, none on the S70's. Why would you think that a pin has a function?
Klaus
Has thanked: 2200 times
Been thanked: 1852 times
Maybe the screw driver was a hangover from the old 850 15" rims with the snap in bolt cover. You needed a flat screw driver to remove those.Also, some of the hose clips have phillips/flat options. I still prefer the flat screwdriver option on those as less likely to strip out.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
My GLT has the full tool kit minus the gloves. My 850 had the gloves, but they were nasty... they should have been incinerated.
While we're on this topic, does anyone know what that square rod is with the bottle opener looking thing? I'll take a picture tomorrow, but I've always wondered what it is. In one of my cars (I think the R) it's attached to the jack.
Hook for the spare tire holder perhaps?
