Manufacturers defect? Topic is solved
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
Hey all...so I'm having trouble with the reservoir that I bought from IPD. it's a Behr unit. You know I thought I have a bad coolant temp sensor..so yesterday I got another one from the scrap yard. Last night as I was changing it...I was lazy and didn't drain anything...I just got a towel and put it underneath. I didn't realize it at first but when I pulled it out..no antifreeze came out and I put the new one in. But shouldn't it have?
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Question is unclear. Should coolant come out of the reservoir, or should it have come out of the thermostat housing. Not clear whether you are replacing the coolant reservoir or the engine coolant temperature sensor from your post.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Been thanked: 4068 times
If you were replacing the coolant level sensor on the reservoir , it is magnetic and works throughout the plastic, so no coolant touches it nor will leak when it is pulled.
MDK
Post by MDK »
Ah... abscate. Now I get it .. magnetic. I guess I'll get another sensor... again. Thanks man.. the dude abides...
