850 2.5L 20 V Rescue Topic is solved
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
You posted pictures several posts back and it looks as if the rear brake pads are
seized based on the look of the rotors, pitted and rusty. Did you fix them already,
if so, I missed the post about it? It is worth checking them.
manovlov
Has thanked: 674 times
Been thanked: 164 times
Post by manovlov »
Good luck !
PeteB
Post by PeteB »
You are posting a lot of info, seems you don't want comments, that's fine.
manovlov
Post by manovlov »
PeteB
Post by PeteB »
You posted this?
download/file.php?id=46784&t=1
That rotor doesn't look "right" perhaps if the car sat for 5 years it might look like that.
Seems there is a language barrier so I will stop posting in your thread.
manovlov
Post by manovlov »
No.
manovlov
Post by manovlov »
Hy guys,
I have a question : May someone tell me where the N° 24 must be plugged (red circled)?
I may have done a mistake while I was reassembling the installation.
Thanks to ones who will help.
What are the numbers corresponding on the second board ?
Manov
(pictures : courtesy of a great car builder)
Capture d’écran 2.jpg (168.02 KiB) Viewed 1531 times
Capture d’écran 3.jpg (77.04 KiB) Viewed 1531 times
Edit : sometimes the solution is nearer than we think...
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
If it's black & white one way valve....it goes to a vacuum tree...at least on '97.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
manovlov
Post by manovlov »
Thanks a lot for your information
Manov
