96 850T check engine light on but no codes
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
I thought the check engine light indicated a fault code but several attempts all result in zero codes found. Should I get a different reader? The only thing wrong with it is it's from Harbor Freight.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- Has thanked: 2199 times
I'm not sure how well these readers read the early Volvos. As a 96 I believe it no longer has the under hood code reader. There are several items on MVS on how to build a basic code reader with cheap components using an LED bulb.
It might be a Volvo Code P1xxxx that the reader can't map. If the light is on, a code is stored.
Make sure the B+ voltage is good and tight
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If the car have auto transmission it could be request from TCM to turn on check engine light and that can ONLY be read via special Volvo scan tool...at least VOL-FCR.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 9 Replies
- 6326 Views
- 14 Replies
- 619 Views
- 35 Replies
- 5002 Views
Last post by henrysin44
- 959 Views
Last post by rspi
- 17 Replies
- 5300 Views
