Anti-skid service needed (brake pressure sensors 1 and 2 out of the range)
dneu
Year and Model: 2004 V70R
Post by dneu »
Today a yellow triangle popped out on my 2004 V70R. iCarsoft Volvo dedicated scanner found this fault "Brake pressure sensors out of the safe range". Scanner cannot erase DTC (prompts DTC erased, but the triangle and the message are still on). I also scanned SAS but the scanner found only "Faulty communication with SAS" Pressure sensors are over $ 300, thus I am reluctant to buy them without being absolutely sure where the problem is.
Has thanked: 1505 times
Been thanked: 3817 times
You need to get the Volvo BCM code, not the text that someone mapped to it on your scanner
Vida is the best tool for this, or else you have to shotgun parts. No magic bullets to diagnosis here
