Got the purge valve to replace, but I'm having a hard time finding the location. I have looked by the fan shroud which seems to be the popular consensus, as well as by the fuel tank (but not the top). This is the part I am referring to.
https://www.ipdusa.com/products/10266/1 ... urge-valve
Have searched all over the internet, but nothing has been found specifically for my vehicle. It's big enough to where you can't miss it, but seems to be somewhere else I'm not looking.
Any help is appreciated in advance. Thank you. (Pictures would help immensely.)
2005 XC90 T6 - EVAP Purge Valve Location
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Looking under the hood, at the driver's side of the motor, look between the air cleaner and the fuse box. in the gap between these three items, you will see it buried with hose and electrical connections. Did the top pop off of yours like mine did? common mode of failure. Oh yeah, if it did, it won't look right, you'll see the disc of the body, and the top with electrical connector will be flopping around nearby!
Current Volvos:
THolland
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 3 times
Hi,
Any chance that someone might point me to the same diagram to locate the purge pump? I am getting these two error codes and trying to chase down the origin but have to get access to connectors/wires on both the valve and pump. If anyone has any guidance on the likely origin on this problem please let me know as well
P2401 Volvo evaporative emission system leak detection pump control circuit low
P2401 -- ECM-433D -- Leakage diagnostic unit, pump -- Signal too low
P2419 Volvo evaporative emission system switching valve control circuit low
P2419 -- ECM-432D -- Leak diagnostic unit, valve -- Signal too low
Thanks,
- Tim
Thanks,
- Tim
Hi there did you fine out What was wrong with P2401 Volvo evaporative emission system leak detection pump control circuit low
P2419 -- ECM-432D -- Leak diagnostic unit, valve -- Signal too low. I am having the same problem 2005 volvo xc90 t6 2.9
P2419 -- ECM-432D -- Leak diagnostic unit, valve -- Signal too low. Need some help how to fix this issue thanks
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The leakage detection pump is mounted to the rear axle subframe. One hose leading to it runs from up beside filler neck in Rt rear quarter panel and the other goes to the rectangular charcoal canister than is also mounted by the rear axle subframe. Those hose connections are larger hoses about the size of heater hose.
- 3717 Views
Last post by XC90V8Pearl
- 10474 Views
Last post by SuperHerman
- 1004 Views
Last post by sleddriver
- 1745 Views
- 10 Replies
- 10437 Views
