2006 V70 NA 100k Should I do the water pump while at it ? Topic is solved
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
I recently purchased a 2006 V70 NA w/ 100k on it from original owner. I'm in the process of doing pcv. Next on the list is timing belt. Question: should I go with complete job (water pump, tensioner, idler) or just the belt. I know popular opinion is while you in there do it all, but I've heard these wp's are good for 200k. Opinions greatly appreciated.
Thanks
Glenn
Been thanked: 504 times
Post by cn90 »
Most people here will tell you to replace the TB, idler and tensioner pulley.
The WP can be replaced at 180K.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
Replace water pump with 2nd timing belt change...per my Volvo dealer.
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
The water pumps generally do have a pretty long lifespan. I just replaced an original one on a car with 262k miles, clean, dry (no evidence of weep hole leak) & the bearing still felt great.
Very easy to do, find the nipple (protrudes off of a hard coolant line) on the rear of the engine, above the oil cooler & that will drain just enough coolant to allow you to replace the pump without a huge mess on the floor.
I use Zerex G-05 for coolant, it's usually $17-18/gallon, but is the correct stuff.
I run the Aisin pumps, like $80 w/gasket & bolts. HEPU pumps seem to have good reviews. I have never run one, but they are like $48 w/gasket & new bolts.
EDIT: I forgot to say something. When I buy my timing belt components I get the entire shah-bang & replace everything that touches the belt. I replace the serpentine belt too. I get all my timing belt stuff from FCP, and each time after that initial change the parts are free. Then everything is always the same age.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
XC70Rider
Year and Model: 2007 XC70
Been thanked: 42 times
Post by XC70Rider »
Costing less than $100 I installed the Aisin WP when I did the timing belt kit at 123k miles. I'll leave the WP alone when I do the belt kit again at 223k miles.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Tough call especially if you don't know the vehicle's history. If you have had it for a few thousand miles then that helps as you can examine it and listen to it. Water pumps will make noises and/or leak before they fail 99% of the time.
Here is the problem - some people have lost their engines due to a failed water pump - others have made it as described above. The original water pump is pretty robust - and failures are few and far between under 150k miles.
Were it me I would price out the Aisin Timing belt kit with and without the water pump and decide if it is worth the extra money and the hour or so of added labor. It may be worth knowing you will have no issues for 100k miles plus and do the timing belt once.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Recommend the Contitech belt kit while there. Are you sure you 2006 is non turbo ? Remember the non turbo engine being discontinued around 2005 ?
GlennG2759
Yes, it is definitely non turbo. After the greatly appreciated input, I've decided to go with the water pump. FCP sells the Conti kit w/ Rein water pump, but I think I'll package up separately and get the Aisin pump. Thanks to all.
Has thanked: 1611 times
Been thanked: 4075 times
I apply my formula as follows
My labor is 25 an hour,so 4 hours for the pump costs me 100 later on if I need to do it,
It’s highly likely that pump will last to the next timing belt cycle in which case the labor is free.
Here’s one last tipping point agaisntvreplacement. ..it’s posdible once in a while, to snap off water pump bolts on this job. Be careful with those and note they have to seal the coolant path, too.
Sorry for coming in late.
oragex
Post by oragex »
On Fcpeuro this seems to be your kit for the belt https://www.fcpeuro.com/products/volvo- ... em#fitment I think the Fcp have a glitch in their system, sometimes they don't show the 2.4 (or base) engine after 2005
