replaced fuel pump. Now I have gas leak
Rgierer
Year and Model: 1998 V70T5
Post by Rgierer »
car 1998 V70T5
When I was removing fuel lines from pump, one hose leaked as it was being removed. It looks like there is an elbow composed of multiple parts and those parts leak.
When I replaced pump,car starts and runs nicely but has a small fuel leak at pump at that specific connection.
Is there a replacement part or a repair which can be done to remedy this issue?
Robin
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Does it leak at the fitting or is it in the hose itself? I have had a fitting leak where just removing the not so "quick connect" and giving it a dab of oil allowed it to seal back up. If it is in the hose or the pipe it gets more complicated,
Rgierer
Post by Rgierer »
It is in the fitting. A dab of oil will be applied today.
Thank you
Robin
Rgierer
Post by Rgierer »
It worked!
After a spot of oil and a liberal application of silicone spray, my problems are gone!
Thank you
robin
