Repair beyond my skill set no crank/no start
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
My '94 has it and so does the Plat. It is very short and has a female spade connector on it.
Here is a picture from the Platinum. I think the '94 has it very close to that position.
Service Starter Connector.JPG (281.68 KiB) Viewed 851 times
cBobs94850T
Year and Model: 850 1994
Post by cBobs94850T »
thanks for the picture Lee I'll go look again and d--v70 my helper is on vacation I'll get those measurements when she gets home Thanks again
cBobs94850T
Lee your Platinum is laid out a bit differ than mine but I did notice a plastic cover over a cable in that area I'll try removing that to look for that wire Thanks
cBobs94850T
Have bigger issue now in playing with starter must have shorted something cause I have no power to dash or interior. Check all fuses and they are good. Any suggestion where to look next thanks
Been thanked: 4068 times
Sounds like your ignition switch has pooped the bed.
Get out the VOM and start tracing per the wiring diagram. You can’t diagnose electrics by symptom very efficiently
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
cBobs94850T wrote: 03 Aug 2019, 11:48 Have bigger issue now in playing with starter must have shorted something cause I have no power to dash or interior. Check all fuses and they are good. Any suggestion where to look next thanks
Are your head lights or brake lights working. May have burned out the big fuse thingamajig?
cBobs94850T
abscate can you point me to those wiring diagrams
Mo Volvo where is that fuse
dj_v70
Year and Model: v70 2003
Has thanked: 7 times
Been thanked: 23 times
Post by dj_v70 »
The wiring diagram links are the second topic under the P80 forum.
MoVolvos
Post by MoVolvos »
cBobs94850T wrote: 03 Aug 2019, 19:56 abscate can you point me to those wiring diagrams
If your head light and brake light are out and the fuses are good as with your others... Not sure where it is but I remember with many other cars there is always a large 100 AMP or so fuse where the positive cable from the battery goes into the fuse box under the hood.
Has thanked: 311 times
Been thanked: 817 times
Try turning the key on and off, and rotating it just slightly back and forth, see if that changes things. If so it is the electrical portion of the ignition switch gone bad.
