They're so easily distracted!
http://www.volvoxc.com/forums/showthrea ... er-goodies
How many drain and fills ?
- Been thanked: 4071 times
Pasting here for posterior- the original 'gibbons' post at the link above
Originally Posted by gibbons View Post
Knowing that I blabber too often here, I don't post a lot of stuff that I personally find interesting. However, I will toss this one out there for consideration. There are 7.5 liters of ATF in the transmission. Some people think it's good for life, which it is, technically. Good right up until the life of the transmission is cut short from dirty ATF. Volvo designed a counter in the TCM (transmission control module) to monitor hours vs load. After a given amount of use, a service message will pop up. I like to error on the safe side, so I just changed mine at 15K miles to get out the "break-in" junk and other generally oxidized fluid.
There are two schools of thought on what to do, easy and hard. Easy is to dump what is in the bottom of the transmission, and replace it. That will leave over half of the old ATF remaining, but diluted with new ATF (better than doing nothing). The hard way is to fork out $300+ to have the dealer "power flush" it to remove all the old. I read in Volvo documentation a way to flush it without the machine, but it looked like a plumbing monster involving magic proprietary wrenches to fit in impossibly tight areas. So I came up with this trick using a $4 vinyl tube, which does essentially the same thing.
1. This is the outlet fitting at the top of the transmission cooler. The line off to the side with the o-rings is no-pressure return line back to the transmission. I pulled the line out, and put in a piece of 9/16" vinyl tube with teflon tape wrapped around the end (for a great seal) in the hole. It fits comfortably tight when pushed in, and didn't leak a drop. I put the other end of the tube in a container.
2. Pull the plug in the bottom of the transmission. about 3.1 liters of ATF will come out. Put the plug back in, and put in 3.1 liters of new ATF (through the dipstick hole) to replace what just drained out.
3. Start the engine. The ATF hiding in the rest of the transmission, cooler lines, and cooler will start to pump out though the vinyl tube into the container, while sucking the fresh fluid into those components. About 2.2 liters will come out before bubbles start coming out, stop the engine then. Measure it with a graduated vessel (pyrex cooking thingy I thugged from my wife), and put that much new ATF back in the trasmission. You need a helper to start and stop the engine, while you carefully monitor the flow. It takes about 1 minute.
4. Repeat the engine start/stop cycle again, pumping out another 2.2 liters.
5. At this point, the bad stuff will be gone and new ATF will be running clear and clean. Measure what you just pumped out, and replace that amount with new. You will be darn close to what you had in before you started, minus maybe a few CC that was left in the tube and on the container side walls. Remove tube and put real line back in cooler.
6. Run engine until hot, and check the fluid level. Adjust to marks on the dip stick. That's it!
Some general notes on this procedure:
- If you can change your own oil, you can do this.
- The ATF I pumped out at 15K miles was a dark mahogany color. In a pint canning jar, it was completely opaque, even holding it up to look at the sun through it. It is supposed to be translucent. It smelled OK. I think my trans has been working fine, my guess is that it was full of break-in particles, which are abrasive and that's why I like to get initial lubes out.
- The drain plug has a magnet in it. Mine had a small amount (if you compiled it, it might be like a grain of rice) of black "paste" on it, that's the metalic sludge from wear. When I do my truck service, I get a table spoon of the stuff. The XC plug had no "glitter" or chunks on the magnet, like I usually expect to see coming out of a geared mechanism. That's nice.
- I ordered 8 liters of real Volvo ATF from Borton for $90, locally it was $22 per liter. I saved enough to buy the PA-300 75w/ch stereo amp, which, by the way, is really cool.
- These transmissions are just too complex to hope that a technician could ever re-build one correctly. Sorry, but that's how I see it. A "new" one (factory rebuilt) is $3200. The number one cause of transmission failure is dirty ATF. I think this is pretty cheap insurance. My next one will be at 50K, and 50K's after that.
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
I read a post by Abscate a while back & he was encouraging dumping just the case regularly. I don't recall what his specific interval was, but something along the lines of every, or every other oil change also dumping the ATF from the case only (it's just a hair over 3 quarts, which @ $6/qt is like $18 in addition to whatever you're paying for your engine oil/filter).
Being new to Volvo's back in 2012, I shamefully admit that I sort of scoffed at this principle initially. I'd usually leave the ATF in vehicles for 40-60k, then do a full "Gibbons" style dump and flush. As time has gone on, though, I have grown increasingly aware of the importance of Abscate's prerogative to perpetually have ATF that is as new as possible. So much so, that I now ritualistically abide by this & just have gotten in the habit of purchasing the 3309 in 12 qt cases. I mean I can basically do 4 Aisin trans's per case(+1) & like $78 pretax (that's 1 case of 12qts + 1 additional qt for fudging).
I sure wish we could get the big jugs of Mannol over here. Pretty cost prohibitive.
My next venture will be to try the ATF Jimmy57's endorses. Maybe I'll wait til I hit 300k on our "dirty Volvo".
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
I was educated by others on the importance of the drain. Anything that settles in the bottom doesn’t get removed by the Gibbons unless it gets suspended. If you drop in 3 fresh liters every 20k miles or so, you are at about 1 cpm cost, pretty small to keep your transmission happy.
- Has thanked: 311 times
- Been thanked: 817 times
Full flush ("Gibbons") when I get the vehicle, then fresh 3.5 liters every 20k - 30k.
daughtersmechanic
- Year and Model: 2001 V70 XC
Even granting that this is important (skeptical newbie here), the "Gibbons" method sure seems like overkill in the extreme. The video (which, I will admit, I skipped around in to catch the important bits) says that he took out and put in 13.5 quarts. That's a lot of ATF-- the equivalent of 4 easier-to-do drain & fills which, according to my calcs, gets you to 90% new fluid.
How does one dispose of used ATF, anyway? The last time I brought oil in for recycling, they put me through an interrogation, afraid that I might contaminate their (already contaminated) oil with some other fluid.
2001 XC70, The Beast, 222K
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
+1SuperHerman wrote: 02 Aug 2019, 21:02 Were it me I would do a drain and fill, drive it for a day or two and then do another drain and fill. After that just do a drain and fill every two or three oil changes.
And then... like cn90, I find simple drain and fill annually, like an oil change, is best.
Also, replace trans cooler lines with this service.
- - Pete -
If you're starting from "scratch" with a vehicle you don't know the history on, in my opinion it's not a bad idea to get rid of as much old stuff as possible. After doing your initial full flush/dump, doing the dump on a regular basis is really all you need. Flushing the cooler - ATF goes in one end of the cooler & comes out the other. When I do the cooler it usually takes me about 11 qts total - 3-3.5 for the case & the remaining 7.5-8 qts for the cooler til it runs clear red.daughtersmechanic wrote: 06 Aug 2019, 10:09 Even granting that this is important (skeptical newbie here), the "Gibbons" method sure seems like overkill in the extreme. The video (which, I will admit, I skipped around in to catch the important bits) says that he took out and put in 13.5 quarts. That's a lot of ATF-- the equivalent of 4 easier-to-do drain & fills which, according to my calcs, gets you to 90% new fluid.
Just find a place that uses a waste oil heater in the cold months. I see you're in MN, so finding a shop that has one of these should be easy. I'd say at least half of the shops south of the cities have waste oil heaters. If they heat with waste oil, they won't give a damn about ATF mixed in with used engine oil.
Edit: one interesting thing I've noticed when doing dumps is with the car on the lift, I almost always get just a hair over 3 qts, like 3.25 or so. If I do it on jack stands - with only the front elevated, pull plug, while it's draining, I then jack up the rear of the car so it sits level, I almost always get just shy of 4 quarts.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- - Pete -
Oh sure, UL listed & everything. Course, lots of DIY type heaters being used. But in the event of a fire you're in deep doo-doo. Or at the least your losses aren't covered.
The one shop I bring used oil/ATF to runs one of these. Last winter, a particularly long, hard & cold one, the guy that owns the shop said he ran through 2,500 gallons.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 741 Views
Last post by rguzz
- 1846 Views
Last post by precopster
- 22 Replies
- 1971 Views
- 13 Replies
- 6141 Views
- 4520 Views
Last post by FCPEURO
