Maybe it's the tailgate latch? I know it's bad, I have to slam it sometimes 5-6 times before it latches properly. The trunk area light also doesn't work, because that circuit passes through the latch.
Short to ground... where is it? Fuse 11A/8 Topic is solved
- Has thanked: 304 times
- Been thanked: 517 times
Re: Short to ground... where is it? Fuse 11A/8
- Has thanked: 1504 times
- Been thanked: 3817 times
Oh yeah. That’s it.
If you strip open the wiring loom in the left tailgate hinge Area , you will find broken wires.
That can also short out your central locking which then takes out the immobilizer.
Search forum for “1999 Oneonta” for pictures
Yeah, I had that harness apart once already to fix my center brake light... it seems that was the only wire that was actually broken, believe it or not! I've been waiting for a good latch to appear at the junkyard.
