Hello all,
I was planning to flush the transmission fluid on my 07 S60 2.5T and was really surprised when I saw this 5 point bolt because I was expecting a torx screw rather. First time I see a 5 point bolt on a Volvo. Do you all think this is original or it could be the previous owner changed it maybe after stripping the torx screw? Any idea what size of 5 point socket this is? Thank you.
Help with transmission fill bolt
neworleans
- Year and Model: 2007 S60R
- Been thanked: 504 times
It is a good thing you ask.
If you ever remove that bolt, you WILL regret BIG time.
For my 2004 V70 2.5T:
Drain: 24-mm bolt.
Fill is via dipstick tube. I posted the trick using the long funnel (search forum).
Drain: 24-mm bolt.
neworleans
cn90, thanks for your reply.
I also have a 07S60R and that one doesn't have a dipstick tube so I thought this one would also have a fill screw just like the R and I noticed this bolt
I just looked for the tube and located it. Thanks again.
Don’t touch that’s one!
- 811638A8-7977-4F2C-B75C-B8486B3A4545.jpeg (258.42 KiB) Viewed 6907 times
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
IPD shows an 07 S60R has the TF-80SC AWD (6 Speed). The 2.5T has the AW55-5X.neworleans wrote: 28 Jul 2019, 20:24 cn90, thanks for your reply.
https://www.ipdusa.com/
Volvopartswebstore.com shows a dipstick for the 07 S60 2.5T in their transmission diagram.
https://www.volvopartswebstore.com/show ... evel=24659
EDIT: TF-80SC AWD Trans Fluid Flush - Drain and Fill Method.
EDIT: Hose Flush - Fuller Replacement
- MoVolvos
Can't tell what year this is but it's the AW55-50 - VERY GOOD VIDEO!
DIY Volvo automatic gearbox flush AW55-50, MANNOL 3309 with oil comparision
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Just in case it was not made clear in the comments above. The bolt, which was changed to a specialized 5 sided bolt to discourage removal, is not for a transmission oil fill hole cover, but retains a ring within the transmission. When unbolted, the ring can rotate out of position and require transmission removal and renovation.
Fortunately, some have found a way to rotate the ring back without removal but I would not want to risk it:
viewtopic.php?t=79032
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
Not trying to be a wise guy here. But that 5 point bolt means that they don't want you to take it out. It holds the bands for the transmission in place... WARNING !WARNING! DANGER WILL ROBINSON DANGER!
- 2071 Views
Last post by polskamafia mjl
- 2869 Views
Last post by Archer
- 10 Replies
- 3877 Views
Last post by Blacklab467
- 1134 Views
Last post by sweedS80
- 1347 Views
Last post by vtl
