leak detection pump location
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
gwahlenberg
Year and Model: 2007 S40
Post by gwahlenberg »
I need to replace the leak detection pump on my 07 volvo s40 and can't not find it's location on the vehicle.
Can someone help me locate it please
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
What is a leak detection pump?
gwahlenberg
code P2402 evaporative emission system leak detection pump control circuit high
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 42 times
Been thanked: 28 times
Post by Cees Klumper »
It's probably just a pump, and the error message is 'leak detection'
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
MoVolvos wrote: 07 Aug 2019, 21:33 What is a leak detection pump?
Think leak down test for the Evap system.
MoVolvos
Post by MoVolvos »
RickHaleParker wrote: 12 Aug 2019, 01:11
Thanks, I googled it to see what it looks like.
So this pump is for the sole-purpose of self-diagnostic of the Evap System?
Is it creating pressure at all times?
MoVolvos
Post by MoVolvos »
gwahlenberg wrote: 08 Aug 2019, 07:48 code P2402 evaporative emission system leak detection pump control circuit high
Not sure if you found it?
GR-372945 - Same parts diagram for both the 2.4 & 2.5. Part #8. I'm not familiar with the Evap System so I could tell either way its location.
https://www.volvopartswebstore.com/show ... evel=24658
MoVolvos
Post by MoVolvos »
Cees Klumper wrote: 12 Aug 2019, 00:05 It's probably just a pump, and the error message is 'leak detection'
Thanks.
gwahlenberg
I found it. It is in a very hard place to get to. The bracket that holds it in place seems to be welded to the frame of the car. I was barely able to take the screws off. Now having hard time trying to take part off. I even tried to bend the bracket but it is not going anywhere... This car is a pain.
Cees Klumper
Sometimes people loosen engine mounts and jack up / tilt the engine, or remove other components, just to get better access, not sure that would help in this situation.
