99 S70 - Time for a timing belt, and other things...
This topic is in the MVS Volvo Repair Database » Time for a timing belt on 1999 S70 Non Turbo
krenekj
Year and Model: Wife says too many
Has thanked: 2 times
Post by krenekj »
Below is a photo I took prior to removing the TB - no solenoids or wires visible so probably no VVT. Thanks for the clarification.
I purchased the IPD cam locking tool when I did this job the first time, and fortunately I still had it in my auto repair box. Yes, locking the cams is VERY important.
93 240 Wagon
99 S70 NA 5sp
02 V70 NA
18 V90CC T5P*
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
MadeInJapan wrote: 03 Nov 2009, 15:48 The main difference is that when you turn your engine clockwise, you need to go past the upper marks by 1/4 of a turn AND THEN GO BACK Counter clockwise to the marks before you take the belt off. I'm providing a pdf from VADIS that details things better.99 S70 Timing Belt.pdf Btw, you don't need anti-seize. Just take your time and you'll do fine!
Are you sure these instructions are for the 99 S70? I don't see any mention of the VVT.
All U.S. market models.
All running and on the road.
Has thanked: 1611 times
Been thanked: 4075 times
The 1999s are tricky
Turbos have VVT, NA engines do not.
Without VVT , the timing belt job is similar to the 1998, but the tensioner is different.
