Switching to synthetic oil...
Mikele82
Year and Model: XC70 04 + C30 T5 08
Has thanked: 30 times
Been thanked: 3 times
Post by Mikele82 »
So my xc70 2004 180,000mil i bought needs an oil change.
former owner extensive records show only regular oil change and 6 months intervals.
IPD recommended and sold me semi synthetic.
https://www.ipdusa.com/products/11929/1 ... kit-125420
ive read a lot to about synthetic causing leaks when switching from regular.
is that true ?
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
No you should not have trouble. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
ionianp2
Year and Model: 2004 Volvo s60
Has thanked: 16 times
Been thanked: 10 times
Post by ionianp2 »
I switched from conventional to full synthetic on my 04 S60 for 3 years now and haven’t had any issues.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
It depends, was the car run on mineral (non synthetic) before ? If so you should be careful at 180k miles. I give a few tips here www.youtube.com/watch?v=IGU-f1MA-VY
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
If it were my new (used) car, at 180k, I'd stick with dino oil. If she isn't leaking oil (?) with dino, why chance it now?
All my cars run Mobil 1 5W30 or 10W30 synthetic, but started using the synthetic at the 1st oil change. I'm a fan of synthetic but believe switching late in an engine's life could be problematic with seals and "loosening" gunk.
Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Since it was serviced regularly there shouldn't be any globs of sludge in it.
Also, given that all this stuff has improved immeasurably over the life of this car AND that you don't live in Death Valley or the North Pole, sticking with a good quality (no bargain weirdo brands) conventional would be OK.
What would be good to do is servicing of the PCV system. If the box and passages are plugged with crud you'd then know what to focus on.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
I'll go with the "there won't be an issue"-camp. Any issues could just as well be caused by using a higher detergent dino oil. But such issues are symptoms of an engine that's already shot and will go soon regardless.
Perhaps throw in an extra filter change after a few k, then you'll see if there's stuff coming loose or not. I've had some extra stuff there sometimes when switching oil brands with the same classification. Probably different amounts of detergents in them.
Katten
Year and Model: S80 3.2 2007
Post by Katten »
This might be a dumb question but I thought all these cars ran fully synthetic oil? Or atleast I would never be recomended anything else by a autoparts store in sweden :)
Rattnalle
Post by Rattnalle »
Katten wrote: 16 Aug 2019, 04:38 This might be a dumb question but I thought all these cars ran fully synthetic oil? Or atleast I would never be recomended anything else by a autoparts store in sweden :)
We haven't had dino oil around for ages anyhow. But the lowest OK spec is ACEA A1 which is really old so they're not that picky really. Unless you've got a turbo and drive it hard.
Has thanked: 1611 times
Been thanked: 4072 times
No dumb questions here, Katten
Every turbo car should run synthetic, and most NA cars also should run synthetic. It’s just better stuff.
The longer drain interval justifies the higher price , not even counting the labor
