EZ oil drain valve anyone?
Mikele82
Year and Model: XC70 04 + C30 T5 08
Has thanked: 30 times
Been thanked: 3 times
Post by Mikele82 »
Anyone using this and can recommend if good?
https://www.oildrainvalve.net/volvo/
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Scotty Kilmer does not like that one. The one he likes in the 04/23/18 video, which is nicer is not available on Amazon any more for some reason. The fear is bumping it off. With a regular nut it won't happen.
This is sitting in the garage some place collecting dust. Am hoping to do all future oil changes with it.
https://www.amazon.com/gp/product/B00LC ... UTF8&psc=1
Been thanked: 4065 times
I’m not a fan but that’s a well made expensive ball valve approach. Well done.
I kind of like rolling under with the car up on ramps as an inspection of other things
Maybe on the T5 with it’s 2-3 month oil change in interval....
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Replacing the drain plug in itself doesn't really make a difference on the work load when you still have to get it up on ramps and take the big plastic cover off.
It would however save me having to stick my hand in the tray full of hot oil to retrieve the plug that I almost always manage to drop :-)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The thing with the drain plug is it gets messy - not to mention when you drop it in the drain pan :oops:
But yes, really important to use a quality valve, not just anyone. Just wonder why don't any car makers use a drain valve from the factory ? Not even high end cars. Not because it's not safe, because it certainly can be designed to be safe enough. Just perhaps they didn't think about it.
The following one is NOT necessarily the correct size for Volvo - just posting for the reviews
https://www.amazon.com/Fumoto-F-108-Eng ... merReviews
Mikele82
Post by Mikele82 »
oragex wrote: 20 Aug 2019, 09:41 The following one is NOT necessarily the correct size for Volvo - just posting for the reviews
Good brand,
for the XC70 its 104 with the 104 adapter
http://www.fumotousa.com/results.php?ma ... .5L++5+cyl.
Mikele82
Post by Mikele82 »
MoVolvos wrote: 19 Aug 2019, 20:58 -
Found it:
https://www.valvomax.com/
Seems the best make, but I feel personally I would probably misplace the second tube piece that screws in, and if i actually go to a service they would need to unbolt it altogether...
just for clarity=drain hole points backwards
EZ one needs adapter/extender because of pan shape, not sure if the valvomax needs it...
IslandV70
Year and Model: 2005 V70 2.4
Has thanked: 2 times
Post by IslandV70 »
I just use my vacuum oil sucker from the top. I never liked those valves.
MoVolvos
Post by MoVolvos »
IslandV70 wrote: 20 Aug 2019, 12:35 I just use my vacuum oil sucker from the top. I never liked those valves.
You mean something like this? Do you warm your engine? I'm hoping to soon use mine for the 1st time.
https://www.amazon.com/gp/product/B00LC ... svolvo3-20
MoVolvos
Post by MoVolvos »
Mikele82 wrote: 20 Aug 2019, 10:57
Found it:
Thanks for the info. If the fluid extractor works well I shouldn't have to crack the oil plug again for all 5 cars :D .
