Anyone using this and can recommend if good?
https://www.oildrainvalve.net/volvo/
EZ oil drain valve anyone?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Scotty Kilmer does not like that one. The one he likes in the 04/23/18 video, which is nicer is not available on Amazon any more for some reason. The fear is bumping it off. With a regular nut it won't happen.
This is sitting in the garage some place collecting dust. Am hoping to do all future oil changes with it.
https://www.amazon.com/gp/product/B00LC ... UTF8&psc=1
- Has thanked: 1611 times
- Been thanked: 4072 times
I’m not a fan but that’s a well made expensive ball valve approach. Well done.
I kind of like rolling under with the car up on ramps as an inspection of other things
Maybe on the T5 with it’s 2-3 month oil change in interval....
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Replacing the drain plug in itself doesn't really make a difference on the work load when you still have to get it up on ramps and take the big plastic cover off.
It would however save me having to stick my hand in the tray full of hot oil to retrieve the plug that I almost always manage to drop
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The thing with the drain plug is it gets messy - not to mention when you drop it in the drain pan
But yes, really important to use a quality valve, not just anyone. Just wonder why don't any car makers use a drain valve from the factory ? Not even high end cars. Not because it's not safe, because it certainly can be designed to be safe enough. Just perhaps they didn't think about it.
The following one is NOT necessarily the correct size for Volvo - just posting for the reviews
https://www.amazon.com/Fumoto-F-108-Eng ... merReviews
Mikele82
- Year and Model: XC70 04 + C30 T5 08
- Has thanked: 30 times
- Been thanked: 3 times
Good brand,oragex wrote: 20 Aug 2019, 09:41 The following one is NOT necessarily the correct size for Volvo - just posting for the reviews
for the XC70 its 104 with the 104 adapter
http://www.fumotousa.com/results.php?ma ... .5L++5+cyl.
Mikele82
Found it:MoVolvos wrote: 19 Aug 2019, 20:58 -
https://www.valvomax.com/
Seems the best make, but I feel personally I would probably misplace the second tube piece that screws in, and if i actually go to a service they would need to unbolt it altogether...
just for clarity=drain hole points backwards EZ one needs adapter/extender because of pan shape, not sure if the valvomax needs it...
- 2424.JPG (17.53 KiB) Viewed 2381 times
- MoVolvos
You mean something like this? Do you warm your engine? I'm hoping to soon use mine for the 1st time.IslandV70 wrote: 20 Aug 2019, 12:35 I just use my vacuum oil sucker from the top. I never liked those valves.
https://www.amazon.com/gp/product/B00LC ... svolvo3-20
- MoVolvos
Thanks for the info. If the fluid extractor works well I shouldn't have to crack the oil plug again for all 5 carsMikele82 wrote: 20 Aug 2019, 10:57Found it:MoVolvos wrote: 19 Aug 2019, 20:58 -
