Did you know? 🤔
91 240 Auto Trans Fluid Mystery....
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
e777
Year and Model:
Has thanked: 1 time
Been thanked: 0
e777
Post by e777 » Fri Aug 16, 2019 1:22 pm
Ok, so I just finished working on this AW70 tranny in my wife's 240 wagon.
I did the trans filter and pan gasket, as well as the tail shaft housing gasket, seal, and tail shaft bushing.
Prior to doing the above, I drained just over 3 quarts of fluid from the transmission pan.
Now, here's the mystery: Before starting the car, I added the exact amount of fluid that I had drained from the transmission.
Then, after letting the car warm up a solid 10 minutes and moving the shifter through all the gears a couple of times, I then checked the dipstick, which showed no fluid - dry dipstick! Checked for leaks and all is OK.
I moved the shifter again a couple of times with car running, still dry dipstick.
So, I kept adding fluid while repeatedly checking the dipstick, and, even after adding two and a half additional quarts, only the very tip of the dipstick is now moist.
With the engine off, different story. The dipstick shows a level 1/4 inch below the maximum (190 deg. hash mark)
So, before I continue to add more fluid, I though I would ask. What in the heck is going on here?!?
Thanks.
Wagons:
93 940
91 240
90 740
86 740
Year and Model: 2001 V70
Has thanked: 35 times
Been thanked: 75 times
United States of America
Re: 91 240 Auto Trans Fluid Mystery....
Post by volvolugnut » Thu Aug 22, 2019 10:14 am
Bentley Service Manual says the AW70 trans has total capacity of 7.8 US quarts and 2.6 US quarts in converter only. When pan is removed, the manual says 2.8 US quarts are needed. If you did not drive the car after filling with oil, the ATF will not be warm. ATF expands a lot when heated by driving. The manual says check ATF level after driving at least 30 minutes. Check in park, engine idling on level. Too little ATF or too much can cause oil foaming and false reading.
If you replaced with all new ATF, the level may be hard to see on the stick.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
e777
Year and Model:
Has thanked: 1 time
Been thanked: 0
e777
Post by e777 » Thu Aug 22, 2019 11:57 am
OK. Got it. Thanks for the information!
Wagons:
93 940
91 240
90 740
86 740
