1999 V70 XC - replaced my engine harness, two wires unaccounted for
meyersv70
Year and Model: v70 xc
Post by meyersv70 »
Recently replaced my engine harness on my Volvo v70 xc there are two wires I can't find a connection to, ones black ones brown/ the black one is near the alternator the other is near the starter. but does not go to the starter.
Reason: improved title
Has thanked: 1848 times
Been thanked: 1710 times
Can you take a picture? It makes ID much easier.
Has thanked: 1505 times
Been thanked: 3818 times
The ECT sensor wire runs near the alternator
The mAP and MAT sensors are near the starter on the induction path
Oil pressure sensor on the block near starter
meyersv70
Post by meyersv70 »
Ect sensor is connected, map sensor is connected. Black and brown wires have metal ends with hole in the center like a ground wire.
meyersv70
Post by meyersv70 »
oil pressure sensor is connected also.?
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
AC compressor clutch?
meyersv70 wrote: 24 Aug 2019, 18:18 Ect sensor is connected, map sensor is connected. Black and brown wires have metal ends with hole in the center like a ground wire.
Those would be grounds. One is on the subframe behind the radiator with an M6 bolt.
Worst case , attach to engine block.
