Does anyone know what specific type of plastic the 850 fuel tank is made of? Is it an HDPE? I may be able to find some symbols on the tank if I pull it.
It takes a very specific kind of epoxy to work with plastics. And if you use a plastic welding rod type of system, it needs to be the exact material or it won't bond. I'm going to repair the crack at the heat shield.
Thank you -
P80 Fuel tank - what type of plastic? [HDPE with Nylon additive] Topic is solved
- Been thanked: 4064 times
ITs going to be one of HDPE, PP, or EVOH
Ill have a peek at mine later today and see if I can smell it.
- Has thanked: 2197 times
- Been thanked: 1851 times
Which P80 was it that had a recall for fuel tanks issues?
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Mine. I believe it has expired some time ago, and my closest dealer is 3 hours away anyway.
The leak is coming directly from the rear heat shield bolt. Many others have said the same thing....6 gallons is all you get before it leaks there.
- BlackBart
This guy says it's polypropylene on a 700/900 series tank -
https://www.volvoclub.org.uk/faq/FuelTankRepair.htm
According to the wiki....
Plastic high-density polyethylene (HDPE) fuel tanks made by blow molding. Blow molded HDPE can take complex shapes, for instance allowing the tank to be mounted directly over the rear axle, saving space and improving crash safety. Initially there were concerns over the low fracture toughness of HDPE, when compared to steel or aluminum.
I think polypropylene will be too brittle at low temp for a tank.
Mine feels like HDPE. If you can wait a few days I can take an IR spectrum on mine and put this to bed.
If you can’t wait, try gluing a piece of hdpe and pp to it, after cleaning. Only one will stick
- BlackBart
I think you're right - HDPE from most of what I've read. Volvo parts man couldn't help.
No hurry, I'll figure out draining my 5 gallons, and drop it in the next week. There are usually some material marks molded in to most products. Funny that HDPE is #2 milk bottles. But I want to find the correct welding rod.
The left heat shield will stay off, but I've heard of someone having it welded to the exhaust system at the tailpipe, so it doesn't come near the tank.
Float test to separate by density link here, if you can get a small test piece somehow
https://www.4spe.org/files/HandsOnPlastics/day4.pdf
