Leak at 6 Gallons
- firestarterpro
- Year and Model: 850 NA - 1995
- Has thanked: 2 times
Heres another close up... May try to do the old lawnmower technique
._____________,
||------|---||---||__\ \___
\=-(@)-===-(@)-=*B
The proudest owner of a Naturally Aspired 2.4L Volvo 850 Wagon of 1995!!!
94 850 NA Wagon was hit and totalled at 350k
96 850 NA Sedan sold at 180k
95 850 Turbo Wagon sold at 260k for parts
95 850 NA Wagon sold at 220K
\=-(@)-===-(@)-=*B
- firestarterpro
Sealed it with the heat from a soldering iron... Seemed too easy. Going to put in a few gallons and see how she goes.......
May put a bit of jb weld around it next if necessary
._____________,
\=-(@)-===-(@)-=*B
\=-(@)-===-(@)-=*B
- Has thanked: 2202 times
That is basically what it would appear to say on the recall, that the tank would crack around those mounts. I would use JB Weld plastic weld Epoxy. Clean and roughen the area around the repair and then build up some epoxy around it. They also make a weld putty material that may also work.
Well found.
Well found.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Literally the exact thing I did last weekend on the upper heat shield mount. Soldering gun + JB weld steelstic. I had to pull the tank out though.
- Been thanked: 4068 times
Info from another thread
The tank material is HDPE with a nylon mix made by DuPont.
It’s recycle code 7. But for repair, treat it like HDPE , RECYCLE CODE 2
- Has thanked: 2857 times
- Been thanked: 1332 times
Good call. Here's the link to P80 Fuel Tank - What Type Of Plastic?abscate wrote: 27 Aug 2019, 20:17 Info from another thread
