Leak at 6 Gallons
firestarterpro
Year and Model: 850 NA - 1995
Has thanked: 2 times
Post by firestarterpro »
Heres another close up... May try to do the old lawnmower technique
._____________,
||------|---||---||__\ \___
\=-(@)-===-(@)-=*B
The proudest owner of a Naturally Aspired 2.4L Volvo 850 Wagon of 1995!!! :o :o :o
94 850 NA Wagon was hit and totalled at 350k :oops:
96 850 NA Sedan sold at 180k :arrow:
95 850 Turbo Wagon sold at 260k for parts :!:
95 850 NA Wagon sold at 220K :arrow:
firestarterpro
Sealed it with the heat from a soldering iron... Seemed too easy. Going to put in a few gallons and see how she goes.......
May put a bit of jb weld around it next if necessary
._____________,
\=-(@)-===-(@)-=*B
Has thanked: 2199 times
Been thanked: 1852 times
That is basically what it would appear to say on the recall, that the tank would crack around those mounts. I would use JB Weld plastic weld Epoxy. Clean and roughen the area around the repair and then build up some epoxy around it. They also make a weld putty material that may also work.
Well found.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Literally the exact thing I did last weekend on the upper heat shield mount. Soldering gun + JB weld steelstic. I had to pull the tank out though.
Been thanked: 4065 times
Info from another thread
The tank material is HDPE with a nylon mix made by DuPont.
It’s recycle code 7. But for repair, treat it like HDPE , RECYCLE CODE 2
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
abscate wrote: 27 Aug 2019, 20:17 Info from another thread
Good call. Here's the link to P80 Fuel Tank - What Type Of Plastic?
Also -> Amazon link
