Are you referring to the plastic trim that runs along the lower side? That should just snap into place, there are clips along the trim. IIRC, there was also some adhesive running across the top and bottom of the trim.
- Has thanked: 304 times
- Been thanked: 517 times
Re: What did you do to your Volvo today? (now Sticky)
- ZionXIX
- Has thanked: 64 times
- Been thanked: 194 times
Yes the one across my door I had to remove and I couldn't seem to get it to snap back on. Maybe I just need more force.bmdubya1198 wrote: ↑28 Aug 2019, 07:53Are you referring to the plastic trim that runs along the lower side? That should just snap into place, there are clips along the trim. IIRC, there was also some adhesive running across the top and bottom of the trim.
- Has thanked: 1502 times
- Been thanked: 3814 times
Check those cups under the springs if its a metallic rattle. 18mm bolt.850 LPT wrote: ↑28 Aug 2019, 07:29 Working on 3 cars simultaneously at the moment.
The 850 has an annoying rattle coming from the back, and I think it's the passenger side.
When I did the rear brakes I forgot to install the retaining springs for the pads. So I will install these to see if it remedies the problem. Cleaned the car yesterday and it's in the garage.
I finally ordered a rebuilt ABS module for the S70 from Matty Moo. That will be installed asap. Still need to replace the cracked hoses of the EVAP system and then hopefully I don't have to erase the stupid codes all the time anymore.
As of a few days ago the 05' V70 sports a nice rear spoiler. Interesting job, nothing like drilling big holes in the exterior of your car. Somehow the car isn't fond of the addition though, now I'm getting a "check stop lamp" warning message.
Well, I did check, and everything seems to be working fine, so I don't know what that's all about.
Dirk
Then bring up those cars for the AC work.
- Clemens
- Has thanked: 473 times
- Been thanked: 219 times
Replaced the heater core in the 94T5M because I startet to smell a little coolant when turning on the heater. i got a hella unit which i thought was oe but i was wrong. the unit i got said tvc or something similar on it.
then i lost one of the new o-rings. so i had to put the old ones back in. then i bent quite some fins while installing the core.
so i actually screwed up on a really easy job.
pathetic ...
pathetic ...
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Donor: 1995 854 10V
Changed the passenger side engine mount on the '01 S60... the old one was pretty shot! I had to jack up the engine quite a bit to even get to the bottom bolt.
I also picked up a 26 gallon Kobalt air compressor today... I love it! It powers my Earthquake XT stubby impact no problem, worked great to replace the mount. Time will tell how it holds up, but so far I'm pretty happy. It's unbelievably quiet, barely louder than my AC vacuum pump. It was a pretty good price on sale too, so I figured it was time to pull the trigger on a new compressor.
- 850 LPT
- Year and Model: 96' 850
- Has thanked: 331 times
- Been thanked: 242 times
The 850 got a little shoe polish treatment yesterday. The trim was badly faded and I always wanted to try this out.
We shall see how long this lasts. But it's super easy to apply and takes only minutes to do the bumpers.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
Well it looks pretty darn good now, hopefully it lasts!
brunocerous
- Year and Model: 1998 V70
- Has thanked: 284 times
- Been thanked: 36 times
Thanks! After another no-crank this morning, I noticed that the battery terminals and connectors were filthy. A quick scrub with a metal brush — plus some battery terminal protector — seems to have done the trick.abscate wrote: ↑27 Aug 2019, 10:12Nope, not the ring. Immob does not inhibit cranking on P80Today, it has a no-start, no-crank condition. I'm hoping it's just the antenna ring.
. No cranks are easy - start by looking for 12V on the remote starter terminal when key is turned to POS III - you need a helper for this. She will help when she realizes she is helping to empty the driveway
That's one chewed-up engine mount! It's so satisfying to see. I can only imagine how much more satisfying it was to swap it out, especially with the new compressor!bmdubya1198 wrote: ↑28 Aug 2019, 19:46 Changed the passenger side engine mount on the '01 S60... the old one was pretty shot! I had to jack up the engine quite a bit to even get to the bottom bolt.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- Has thanked: 2652 times
- Been thanked: 1242 times
New tools light a fire under me to get things done. I love new tools.
- June
- Has thanked: 523 times
- Been thanked: 261 times
Like a new credit card!
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
