2007 xc 70 turbo 230k miles
raquette
Year and Model: 2010 xc90, 2007 xc70
Been thanked: 4 times
Post by raquette »
oil is accumulating on the rubber hoses (at the clamps) that go to the turbo. no change in performance.
what is causing this and what is the remedy?
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Do you mean this?
I think this is mostly oil vapor leaking. i've tried to tighten all the clamps but it was still leaking.
I changed with good silicone hoses and T-bolt clamps, works fine.
Someone here suggested that excessive leaking could be the cause of a bad breather system.
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
My rubber intercooler hoses are nasty... it's not exactly indicative of something wrong, but the hoses should be replaced.
I wouldn't be surprised if it was related to a backed up PCV system... my '01 S60's hose looked similar to the pictured above and that PCV was pretty bad. Plus it makes sense... more blow by=more oil in intake tract=oil-saturated IC hoses.
Has thanked: 1613 times
Been thanked: 4078 times
Antoine240bk wrote: 02 Sep 2019, 08:12 Do you mean this?
Nice hoses and clamps. That bottom hard pipe-intercooler pipe is the one that gathers up all the oil and nastiness - if you are on a budget do that one first. The rest you can clean and put new clamps and get away with it.
