P0101 & P0102 not clearing
eamonnpetty
- Year and Model: 2009 Volvo S60 2.5t
I recently cleared codes P2188: System too rich at idle & P0442: Small evap leak. Now I am getting codes P0101: MAF circuit/performance issue & P0102: MAF low input. I tried clearing those codes but every time I start the car the check engine light comes back on. Any help?
Quickest way is to do a smoke test, find the leaking vacuum hose/fitting, then try clearing again.
You can also look at the fuel trims to confirm the leak before you look, but on a 10 year old car, I wouldn't bother with the confirmation step
