cooling system pressure(normal)
dublin19
Year and Model: 1997 v70
Post by dublin19 »
Hi all! can someone tell me how many bar or psi pressure is normal in the cooling system when the engine is warm? (if the thermostat is open) for cooling water above 90 degrees Celsius? (petrol turbo 850 v70 s70)
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
Green cap 1.50 bar. June
BTW the black cap found on older Volvo cars like the 1990 240 is .75 bar, both the green and black caps interchange even on my 2004. I ran the black cap until earlier this year when my mechanic insisted on putting the green cap back on and promptly the coolant lines to the oil cooler leaked, and last week the heater core... we figured by using the black cap the boiling temperature only drops by 20°F which is still way overheated. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
dublin19
Post by dublin19 »
June wrote: 02 Sep 2019, 14:39 Green cap 1.50 bar. June
I have a green cap. Up to 1.5 bar. does this mean that the cooling system is up to 1.5 bar in normal operation?
June
Post by June »
dublin19 wrote: 03 Sep 2019, 13:38
Yes. When it is at operating temperature the cap will regulate the system up to 1.50 bars. Anything over 1.50 bars the cap will vent the excess pressure. On a cold winter's day the pressure will be lower at operating temperature where as a 100° muggy Florida day it likely reaches the full 1.50 bars driving in traffic quickly. June
My Volvo cars owned
1996 960 ordered
dublin19
Post by dublin19 »
June wrote: 03 Sep 2019, 13:47
Thanks for the quick response! I measure the exhaust gas in the expansion tank sure because my upper radiator hose is hard enough.
that's why I questioned the amount of system pressure.
June
Post by June »
dublin19 wrote: 03 Sep 2019, 14:08
If the upper hose is instantly tight with pressure, you need to check for exhaust gasses immediately. The pressure should build with temperature and dissipate quicky if the radiator is cooled quickly. Such as spraying the radiator with a garden hose causing a rapid temperature drop or getting on the expressway on a 0° day. June
My Volvo cars owned
1996 960 ordered
dublin19
Post by dublin19 »
June wrote: 03 Sep 2019, 14:24
I only feel the hose hard with the warm engine running. above 85-90 degrees Celsius. I would like to know how hard the top radiator hose must be if the engine is very warm
June
Post by June »
Really tight. Also hose should stay tight after engine has been shut off. If the pressure disappears instantly upon turning the engine off is another indication of trouble. The pressure should slowly dissipate as the engine cools and the pressure should build with heat as the engine warms up. It's due to the water expanding with heat / contracting as cooled. June
My Volvo cars owned
1996 960 ordered
