AW55-50SN woes-easy to repair? Topic is solved
Repairing a AW55-50SN Transmission in a 2001 V70
Hello...I am ready to drill the hole and destroy as much of my filter as I can. Could you tell me how precise I need to be with location? I saw that here the washer needed to be ground, so can we Drill in the flat area? Let me know what you think. Thanks!
mygreent5
- Year and Model: 850 Wagon T5 1996
my v70 t5 having same problems as tread.
The car can move a few hundred meters only.
Then I drain and fill 3.5 liter each time around 5/6 times in the span of 6 months.
The car can moves 500-800 km before check light pops up.Transmission need service.
code is P0740 and P1618.
When the check light pop up.. The letter D etc on meter disapear.I stop the car/engine then restart..The leter D etc is ok again.
The car moves around 30/40 km before check light pop up again...when this happen,it gears feel some slipping.. and a bit jerky.
any comments? tq in advance.
- Year and Model: Lots
- Been thanked: 128 times
Not a filter problem. My car didn't have any codes when the filter was clogged, however 2 years later I got codes for solenoid 2 or 3 (can't recall) and I gave the car to the giant crusher in the sky because of this and other issues (heater core, head gasket & brake controller)
If codes point directly to a particular solenoid then you should have that solenoid replaced or have a rebuilt valve body fitted.
- Has thanked: 1611 times
- Been thanked: 4072 times
Is the best diagnostic for the clogged filter the whining off the pump being stArved for fluid?
That's right Abscate it was the case on my car.
The whining noise was pretty loud if you had the window open or if you had someone else rev the car in neutral. It was just like an electric motor sound.
I suppose someone unfamiliar with the sound of their own engine might dismiss it as just engine noise but I was pretty familiar with the natural sound of my T5.
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
What an amazing resource! I feel guilty stopping in to the forum so infrequently. Other than regular maintenance, my '05 XC70 has been a solid car. It has a bout 275k kms on it now, and has had the transmission flushed three times since I bought it at 144k. We were overseas on vacation, and my son drove the car for a while, and reported some bad shifting and whining sounds. Testing it this morning, it would barely shift into drive or reverse, and the loud whine that changes with engine speeds that had been faint for the last few months was now quite loud.
I'd been shopping for replacement vehicles this morning, planning to ditch this otherwise great car for parts. Now I'm going to have a go at this repair! Thanks to precopster, cuhfs, and everyone else involved.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
renns
OK, have Magnefine 3/8" filter on order. Here's the link for those that need it. Someone speak up if I ordered the wrong one, and I'll edit this post ASAP!
Magnefine 3/8" Tranny Filter
Will need to check my large tap stock, but I may not have anything big enough for the job. What are the thoughts on going up to something like M15x1.5? Here's a kit that has six bolts and a tap for 15 CanuckBucks.
M15x1.5 Tap Kit
M15x1.5 Tap Kit
renns
I see from this thread that people are punching holes in the filter via the skewer method. In order to open the filter medium further, what about bending a hook in the end of the skewer, such that it catches on the filter material when being pulled back out? That might rip the filter open further, and possibly even pull some of the plugged filter material out the hole. I'll experiment with this idea tonight. I found a 3/8" NPT pipe tap in my toolbox, and plan to use a pipe plug like the one shown below to seal up the wound.
renns
The transmission has been drilled, tapped, and filter poked. I was unable to pull any filter material out. It feels like a fine metal mesh to me, and by inserting and levering back and forth with a poker, I was able to hear the filter screen tear open. On first puncture, a large quantity of oil gushed out, seeming to confirm a plugged filter screen.
To flush any remaining metal chips out of the transmission, I've repeatedly poured 3 liters of diesel fuel down through the dipstick hole, allowing it to run out the newly drilled hole in the bottom of the transmission. As temps are cold in Canada, the ATF pours too slowly to get good flushing action, which is why I switched to diesel. The catch pan is examined after each flushing, and contaminants filtered out prior to pouring through again.
I plan to do a Gibbons flush immediately on startup, to again try to ensure a clean system prior to trying to drive the vehicle. The filter is due to arrive shortly, and the test drive will need to wait until that time. Fingers are crossed!
- 11 Replies
- 4589 Views
Last post by precopster
- 1946 Views
Last post by BEJinFbk
- 16 Replies
- 15126 Views
Last post by vt9000cse
- 1722 Views
Last post by dadyer
- 1144 Views
Last post by matthew1
