Rear swaybar 850 turbo.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 24 times
Forgotten what people think on this subject. It's a wagon 850t with a tight suspension overall. Does handle a bit on the sloppy side when headed in to turns (feels like a boat, basically). Pros and cons to a rear sway bar, where to find one and what size should it be? How much is it likely to help with cornering?
- Has thanked: 1850 times
- Been thanked: 1712 times
I still find it strange that Volvos came with the rear anti-sway bar as an option. I understand there are the location points available on the rear axle for one. They were know to rust and break with age. I wonder if V/S70 parts would fit?
I know a regular AWD V/S70 front (like my R) anti-sway bar will fit a FWD. Rear though is totally different.
I wish you luck, but they do make a big difference at the back. On my 'R' I swapped the IPD HD front for a regular 'R' one and didn't notice much difference. The rear is still the IPD one re-finished with new bushes. Rear of car is nice and tight, but would replace with a regular one if I had to.
- Has thanked: 292 times
- Been thanked: 765 times
I would be surprised to see a T5 without a rear sway bar, did you look? Anyway it is entirely worth it, easy upgrade, try to grab one from any P80 FWD so equipped at the junk yard. If you can, get a thicker bar e.g. from a T5. However Volvo mixed and matched the bars a lot, you can't be sure what is on a given car. The best way to tell what a bar is, is by the paint splotches on it:
front sway bar part #s:
9173982 O.Dia 20 mm (marked red)
9173983 O.Dia 21 mm (marked yellow)
9173471 O.Dia 21.5 mm (marked yellow/blue)
rear sway bar part #s, probable O.Diameter:
9191459 (marked green) 19.5 mm
9191461 (marked yellow) 20 mm
9191462 (marked blue) 20.8 mm
9191494 (marked black) 21 mm
Or spend up and get bars from IPD, I've never gone that route though.
All FWD P80 cars use the same rear sway. AWD is different, no swapping there; is there even an AWD rear sway?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 337 times
The wife's '97 GLT didn't have a rear bar on it. The rear end always felt a bit "wollowy".
It has a set of 850R bars on it now.
- Has thanked: 1505 times
- Been thanked: 3818 times
IPD heavy springs and a Sachs shocks all around....nice and tight
rguzz
Thanks. Yes, might not be a miraculous improvement adding a rear bar. Have a strut bar also ( I realize the controversy) but hoping the combination, strut bar and rear sway will make for an improvement. Not a huge investment if I find a used rear bar, or even go for a new one from Volvo. Haven't spent any $$ on the car in three whole months, so I think I will go for it. Thanks again for the input.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Can't comment on the 850 chassis in particular, but generally, adding more anti-roll to one end of a car (independently of the other end) will tend to reduce grip, transferring load to the other end. Adding rear stiffness while leaving the front alone will increase the car's tendency to oversteer. These cars are tuned very conservatively, and the rear suspension is specifically designed to minimize oversteer, so adding rear anti-roll (and/or softening up the front end) will lively up handling at the limit, but it's hard to quantify.
For what it's worth, nobody seems to have ever said a harsh word about the IPD sway bars. They discontinued their "track spec" kit, which had a stiffer rear sway bar.
- 13 Replies
- 2188 Views
Last post by GlennG2759
- 960 Views
Last post by mike:
