Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
transmission help
t5lunchbox
Year and Model: 1998 v70 t5
transmission help
Post by t5lunchbox »
to make a long story short i am going on my 3rd transmission (if i decide to do it again) in 2 years. could not afford $6k+ for a rebuilt one so i went the junkyard route.
the 1st time was the flashing arrow and second was just slippage. this time it's slipping again.
with the flashing arrow i could turn off the car and wait a few minutes and turn car back on and drive it about 5 feet before it would act up. this time i can turn car off then back on and drive 1/4-1/2 a mile before car acts up. rpms just climb w/ no acceleration.
every time i changed trans i changed out the torque converter and flushed pretty good.
now both trans would act up almost exactly one year from install. again, almost a year to date.
i never did change out the trans computer. should i have? if putting new trans was i suppose to do a relearn procedure or something like that? the reason i ask that (relearn) is because we had a vw at werk that got a newer trans and NEEDED a relearn.
1998 v70 t5 with some bolt-ons. i don't drive it too hard but do spirited runs from time to time.
i can answer more questions in further details as best as i can if need be.
thank you
nico
1998 v70 t5
1992 gmc typhoon
2006 magnum srt8
kallekula
Year and Model: S70 2000
Has thanked: 40 times
Been thanked: 33 times
Post by kallekula »
What oil did you use?
How long is one of those old ones supposed to last? Youre buying from the junk yard so i mean i dunno.
The 55-51 55-50 whatever the five speeds are called usually go out around 100 something. Depending on how often the fluid was changed of course. Volvo claimed/claims (?) no service is required but that was/is kind of a weird thing to say.
BMW 540i 2002
S70 Base 2000
t5lunchbox
i used dexron 3
vehicle is an automatic and has over 200,xxx miles.
i can't imagine everyone else is going through the same ordeal as i am with transmissions which leads me to believe i must of done something wrong or forgot to do something or i just have super bad luck with transmissions.
1998 v70 t5
1992 gmc typhoon
2006 magnum srt8
June
Year and Model: 2004 S80 T6
Has thanked: 379 times
Been thanked: 192 times
Post by June »
t5lunchbox wrote: Fri Sep 06, 2019 6:17 am i used dexron 3
A used transmission is as old as your car minimal. 99 or 00 the 5 speed replaced the 98 4 speed. So you're rolling the dice on a old used transmission. Maby you should consider getting a shop to rebuild it rather than pouring more money into another used transmission. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
t5lunchbox
i payed $1100 (a lot for me) the first time at werk and got the second under warranty through my werk place.
still checking to see if i can get another warranty replacement.
'99-'00 replaced the '98---does that mean i can use the '99-'00 auto trans... with or without trans computer?
thank you for your replies
nico
1998 v70 t5
1992 gmc typhoon
2006 magnum srt8
wizechatmgr
Has thanked: 27 times
Been thanked: 73 times
Post by wizechatmgr »
t5lunchbox wrote: Fri Sep 06, 2019 6:04 pm i payed $1100 (a lot for me) the first time at werk and got the second under warranty through my werk place.
nico
Don't quote me on this but I thought (perhaps incorrectly) that the '99 ran CAN-BUS and that the transmission might not be compatible. Someone please correct me on this if I'm wrong...
1999 V70 XC AWD 2.4 T -- ~193k miles
1998 V70 2.4 NA -- ~180k miles
Has thanked: 504 times
Been thanked: 1506 times
nico
Transmission computer changed between -1998 and 1999-2000 models
I doubt they mingle well.
Clemens
Has thanked: 136 times
Been thanked: 67 times
Post by Clemens »
and opposed to the earlier post: these trannies do NOT necessarily go out around 100k.
my 96R has 200.000 miles on the dirst tranny (knock on wood) as well as my 95 10V with the same mileage. I know quite some people with high mileage 850ies on their first AT.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
greg850r
Year and Model: a long list
Been thanked: 11 times
Post by greg850r »
Clemens wrote: Sun Sep 08, 2019 1:53 pm and opposed to the earlier post: these trannies do NOT necessarily go out around 100k.
I've had a lot of them that over 200xxx on them and no trans problems The only auto box I ever saw die was a 160xxx miler I bought with the trans already bad.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
Clemens
Post by Clemens »
Returning to the original question: I don't think there's anything wrong in particular what you did. Maybe this time try finding a donor car with a running tranny, they can be found dirt cheap depending on where you live. If you go the junkyard route, try to find one out of a wrecked car. Because if it is not wrecked good chances are a motor or tranny problem got it there in the first place.
Summer: 1996 855 R
Donor: 1995 854 10V
