Leds also won't give a correct beam pattern for lows. Even tiny differences from how the filament in the halogen bulbs look ruins the beam. Same with HID. This is unless you fit a aftermarket projector lens optimised for a different kind of bulb in there of course.
Brighter lows?
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Re: Brighter lows?
reverend
- Year and Model: 2006 V70 2.5t
- Has thanked: 2 times
- Been thanked: 3 times
If you have H11, these bulbs: https://www.amazon.com/dp/B00GZHC2L2
should work well for you. That's assuming you don't have faded plastic lenses, in which case replacement is called for (polishing is pretty much pointless even if it LOOKS perfect, it isn't).
Focusing on Kelvin is generally pointless too. I think the highest you really want to go is around 4000-4200 before you start harming your nightvision without appreciable improvement in what you see. CRI is generally shite in car bulbs too, mostly because it's not particularly conducive to safety to have a higher CRI in the bulbs.
Aiming your lights is vital too - though even my local dealer says "we put it up against the wall", which is bullshit, but good luck finding a shop with proper aiming machinery.
OR - if you need to replace your headlamps anyway, get the European ones where you have an H7 in the low and you have a better selection of bulbs to stick in there.
