Wastegate flapper
Jhagins1
Year and Model: 97 855R
Post by Jhagins1 »
Guys I am rebuilding the head on my 850r and have the turbo off and decided to do it while off. The wastegate flapper appears to be able to move up and down a lot. If not I. The right position it allows a gap at the top or bottom of the port. Is this normal.
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
I don't think it's normal but I can pull one off the shelf tomorrow and check. Meantime, a pic would be helpful if you have the parts on the bench.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
It's normal for the flapper itself to move around a bit when it's open, but when the wastegate is closed (held shut by the actuator) it should seal tight.
Jhagins1
Post by Jhagins1 »
I will take some pics. I jb welded it. The door fits in a bushing and the bushing moves up and down allowing it to leave a gap. I got the bushing to stop moving so now just the door moves. No more up and down. Just open and close.
bmdubya1198
Jhagins1 wrote: 11 Sep 2019, 09:17 I will take some pics. I jb welded it. The door fits in a bushing and the bushing moves up and down allowing it to leave a gap. I got the bushing to stop moving so now just the door moves. No more up and down. Just open and close.
Uhhh... sounds to me like you're setting yourself up for boost issues, whether that's over- or under-boosting depends on how you JB welded it.
Pics will be necessary here.
Jhagins1
Post by Jhagins1 »
How do I add a picture
bmdubya1198
Go into "full editor & previrw" or click "post reply" at the top of the thread, then just below the text box, you can select "attachments" and upload it from there.
Otherwise, you can post from an image hosting site like Imgur using the BB code link option.
Jhagins1
Post by Jhagins1 »
The part that is jb welded is the bushing that the flapper shaft sits in. It is the part that is moving up and down.
bmdubya1198
Ah, I see. I don't think I've seen that repaired that way before... best bet is to get a new turbine housing.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
That's odd. I'd be concerned about that JB Weld inside the housing coming loose and breaking apart after so many heat cycles. Debris like that would not be great to hit spinning turbines and go down the intake into engine.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
